Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jul 23 2008, 12:48 AM
Now I know why GT grills are so expensive...they're a lot of work to put together. After looking at Eric Shea's thread, Pelican's, and a few examples of others who bought or are making them, I said to myself "I can do that!"
I tried to incorporate the ideas that I liked and went off on my own to make my own version of the GT grill. Even though they all look similar from 3' they're not...look close. Here's my almost finished product. It still needs painting and trim beads on both grills. The grills are not attached yet... I'll post the painted version tomorrow...hopefully. Here is the frame with rounded corners...hopefully to reduce stress cracks. To secure the back on the second grill, I welded in a 1" X 18" strip on the underside of the grill and made tabs on the grill by flattening a few areas. The tabs slide into the space between the braces and the strip that I made. No fasterners are needed. The front is secured by the pins of the first grill and a couple of the pins going from the top and side. You're looking at the small lip welded on the underside. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:30 PM |
