oil leak.....found it...., found it, now to fix it.... |
crash914 |
Jan 22 2004, 03:47 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Ok, I found the source of the constant wet bottom of the block...I was thinking that it was the push rod tubes, so I replaced all O rings...it wasn't.
After pulling the heads, I noticed that the holes for the head studs that are inside of the valve covers were wet. AAHHHH!!! There is no seal on the flat washer, generally you don't use seal on head bolts, so, what do you all use to prevent the weepage around and under the washer? I am thinking a non hardning permatex below the washer and teflon thread seal on the studs... Thoughts? herb |
Lo-Fi Version | Time is now: 17th May 2024 - 10:39 PM |
