1.8 or 2.0? |
1.8 or 2.0? |
Mavrick272 |
May 31 2008, 12:10 AM
Newbie Group: Members Posts: 41 Joined: 24-April 08 From: Rockford, MI Member No.: 8,962 Region Association: Upper MidWest |
Hi guys
I am not sure if my 914 is a 1.8 or 2.0 It's a '74 It is missing the rear emblem (I wanted to buy a new one from Pelican Parts but I wanted to be absolutely sure I got the right one) is there a way I can tell from the VIN or some other way? Also, does anyone know if the factory rear emblem for 1974 models was "914 1.8" or "914-VW-Porsche"? thanks P.S. my VIN is 4742911300 |
chris914 |
May 31 2008, 12:12 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Mavrick272 |
May 31 2008, 12:18 AM
and for my next dumb question...
(drum roll please) Where might I find this mystical engine number? |
chris914 |
May 31 2008, 12:25 AM
On top of the engine where the case joins together.
All questions are good, no worries. |
Mavrick272 |
May 31 2008, 12:31 AM
thank you very much
So this engine number is just a 2 letter code, right? |
chris914 |
May 31 2008, 12:41 AM
Two letters followed by numbers.
The two letters identify the type of engine and the numbers are the engine's serial number. |
chris914 |
May 31 2008, 12:43 AM
Mavrick272 |
May 31 2008, 09:53 AM
well
I looked and all I found was a 13 digit VIN thing up by the distributor it reads: ZUNDFOLGE1432 (IMG:style_emoticons/default/WTF.gif) |
JeffBowlsby |
May 31 2008, 09:57 AM
914 Wiring Harnesses Group: Members Posts: 8,523 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Look in these places:
For the 2.0L you will need to disconnect the vacuum hose to look down to the case, and its probably dirt covered down there. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
May 31 2008, 10:10 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
So, to start with, the location of the engine serial number will tell you right away if it is a 2.0 liter or a 1.7/1.8
The 2.0 liter (as shown above) serial number is right in front of the oil filler housing on the raised area of the case that the oil filler is mounted. The 1.7/1.8 liter serial number is on top of the case, towards the rear of the motor, nearest the flywheel, just under the plenum. So, location is the first clue, then the numbers are the second clue. There could be a motor (I have seen all sorts of mismatches) that has a 1.8 liter case and crank with 2.0 liter heads...so dont go by the heads, go by the case. Yes, you can build anything you want from any case, but if you have a 1.8 liter case, assume its a 1.8 liter crank unless you want to tear down the motor to measure up everything. Rich |
Mavrick272 |
May 31 2008, 10:19 AM
Thank you, gentlemen
I will go take a look and see what I can see |
Mavrick272 |
May 31 2008, 10:37 AM
Yep, I found it
and she's a 1.8 she's a 1.8 lady woah woah woah she's a 1.8 lady thanks again, guys |
type47 |
May 31 2008, 04:53 PM
nice! 74 1.8L. still have the L-jet fuel injection system? i went to a swap meet at carlisle PA a couple of weekends ago and of the 6 914's there, 5 were 1.8L L-jet!
Mavrick272 |
Jun 1 2008, 10:41 AM
yep, she's still got the stock fuel injection
roadster fan |
Jun 1 2008, 02:11 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Just playing devil's advocate here, but if the car didn't have the L-jet still, you wouldn't be able to tell for sure what engine you had by the number on the case right?
You would only know what type of case it may have been built from right? Internals could be 1.7, 1.8, 2.0, or big bore if it had been rebuilt. Jim |
stateofidleness |
Jun 1 2008, 04:10 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
not to sound dumb, but i thought the easiest way was to look at the air cleaner?
TheCabinetmaker |
Jun 1 2008, 04:16 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh, I have a 75 1.8 car and engine with a 2.0 djet. Big square box don't mean its a 2.0?
jesiv |
Jun 2 2008, 10:03 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Lo-Fi Version | Time is now: 30th May 2024 - 12:24 AM |
