Where's the temp sender?, '74 1.8 |
Rav914 |
May 31 2008, 07:16 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Sorry for the ignorance, the Haynes manual didn't say nor could I find it in the search.
I bought a new VDO guage for the center console to replace the non-working (I think) old guage. The new guage is right from the box so I'm assuming it's a working product. The needle on it too doesn't move off zero. So I'm assuming (that word again), it's the sending unit. But I don't know where it is and staring at the engine for 15 minutes didn't help either. Thanks! Nate |
914Sixer |
May 31 2008, 07:50 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
More than likely, your wire from the sending unit on the bottom of the engine is missing or melted into. Next, check to see if it is plugged in to the wiring harness by battery area. Probably one or the other. By the way the later unit uses a different sending unit.
May 31 2008, 07:54 PM
oil temp sensor...ok
Taco plate on the bottom of the motor. Wire runs up the front of the motor and attaches to a connnection right under the ECU....its a great place for corrosion...whoda thunk. There is also another connection under the carpet, just in front of the shifter, passenger side of the tunnel. Rich |
Rav914 |
May 31 2008, 08:06 PM
Thanks!
type47 |
Jun 1 2008, 07:52 AM
i saw this on another car this weekend at a pca tech session. a VDO gauge, not a porsche console gauge, was hooked up to the taco plate sender. i was curious if there was a mis-match between sender and gauge but the owner was satisfied with the temp readings.
orange914 |
Jun 26 2008, 10:11 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
More than likely, your wire from the sending unit on the bottom of the engine is missing or melted into. Next, check to see if it is plugged in to the wiring harness by battery area. Probably one or the other. By the way the later unit uses a different sending unit. do you know what color the wire is (harness side) any pictures mike |
rhodyguy |
Jun 26 2008, 10:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
it's the unattached wire adjacent to capped off j-tube. should be green.
Jun 26 2008, 11:50 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
should be green. green with a black stripe, to be precise ... (IMG:style_emoticons/default/bye1.gif) Andy |
MrKona |
Jun 27 2008, 04:28 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
And here's a picture of the taco plate on the underside of the engine case. If you have just a flat plate there, you're missing the sending unit.
Attached thumbnail(s) |
Rav914 |
Jun 28 2008, 02:49 PM
Yes, I have a flat plate back there. Smells like a winter project to me. (IMG:style_emoticons/default/biggrin.gif)
Thanks for the pictures. Nate |
type47 |
Jun 29 2008, 05:15 PM
Yes, I have a flat plate back there. Smells like a winter project to me. (IMG:style_emoticons/default/biggrin.gif) buy a "taco" plate and install it next oil change (IMG:style_emoticons/default/smile.gif) |
kpfoten |
Jun 29 2008, 11:37 PM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
Is there another temp sender that runs a green light (?) on the dash? If so, where is it located? I want to make sure mine is secure.
Thanks |
type47 |
Jun 30 2008, 08:06 AM
no. the green light is oil PRESSURE (didn't mean to shout). the oil pressure sender is next to the distributor on top of the engine, passenger side.
ericread |
Jun 30 2008, 10:27 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
And here's a picture of the taco plate on the underside of the engine case. If you have just a flat plate there, you're missing the sending unit. Hey Bryan; I noticed your TACO plate has a cable strain relief tab. I have never seen one like this before? Is this a stock unit, or did you fabricate the strain relief tab yourself. It looks like a good idea to me! Eric Read |
MrKona |
Jun 30 2008, 10:38 AM
And here's a picture of the taco plate on the underside of the engine case. If you have just a flat plate there, you're missing the sending unit. Hey Bryan; I noticed your TACO plate has a cable strain relief tab. I have never seen one like this before? Is this a stock unit, or did you fabricate the strain relief tab yourself. It looks like a good idea to me! Eric Read Hey that's interesting, I never thought about it. I didn't fabricate it, that was the way it came on the core engine I bought a couple years back. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:47 PM |
