Is This Going To Be A Problem, Valve Damage? *NEW PHOTOS, COMMENTS RQSTD* |
kconway |
Jun 3 2008, 07:25 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm changing out the pushrod tubes and seals and found this. Do I need to replace this valve?
Kev |
BarberDave |
Jun 3 2008, 07:33 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Absolutely...... YES......... Dave (IMG:style_emoticons/default/slap.gif) |
PeeGreen 914 |
Jun 3 2008, 07:34 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Yes. You want it to be a nice smooth flat surface.
BarberDave |
Jun 3 2008, 07:38 PM
\ All of them ........ Dave (IMG:style_emoticons/default/slap.gif) |
SLITS |
Jun 3 2008, 07:39 PM
To save the valve, you could have the tip machined flat and use a lash cap.
BarberDave |
Jun 3 2008, 07:44 PM
I would throw away all of them and the rockers, change just 1 and next week others will go. Matter of fact I would have a good head shop ,( Len's ) rebuild them. Dave (IMG:style_emoticons/default/slap.gif) |
BarberDave |
Jun 3 2008, 07:48 PM
SLIT"S Wouldn' t machineing the valve remove the heat treat makeing it to soft even for a lash cup to last very long? Dave (IMG:style_emoticons/default/slap.gif) |
kconway |
Jun 3 2008, 07:49 PM
Can someone explain to me what the likely cause is. Car ran fine. Need a cheaper solution to rebuilding the entire head and pretty sure I'm not the guy to do it. Can I take the whole head to RIMCO or do they just do the machining?
Just like peeling an onion... |
ericread |
Jun 3 2008, 08:56 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
SLITS |
Jun 3 2008, 09:14 PM
SLIT"S Wouldn' t machineing the valve remove the heat treat makeing it to soft even for a lash cup to last very long? Dave (IMG:style_emoticons/default/slap.gif) The lash cap is hardened and fits over the tip of the valve. The hardened surface takes the sliding of the rocker tip otherwise the rocker tip would "dig" into the malable surface and "mushroom" the stem tip. Didn't say it was the way to go, but it is one way. |
Allan |
Jun 3 2008, 10:53 PM
brer |
Jun 3 2008, 11:17 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
You can get it done right here in san diego. Better than RIMCO by a mile.
Around 600+/- for the pair, if no welding. Thats a rebuild. |
kconway |
Jun 3 2008, 11:20 PM
sean_v8_914 |
Jun 3 2008, 11:21 PM
if the engine is assembled and still in the car...and you don't want to drop it all, put lash caps on all 4 valves and drive it till she spits chunks
kconway |
Jun 3 2008, 11:22 PM
brer |
Jun 3 2008, 11:49 PM
You can get it done right here in san diego. Better than RIMCO by a mile. Around 600+/- for the pair, if no welding. Thats a rebuild. You saying they would replace all the valves, springs, rockers in both heads for ~$600? Whats the place your speaking of? don bolton Bugpatch 619-449-8670 thats just ballpark, you would have to talk to him about what NEW parts you want, and how bad your heads are of course. |
Jake Raby |
Jun 3 2008, 11:54 PM
Brer,
I never knew that was the "don" you were referring to... As far as that valve, well its a classic example of a valve that was ran loose for many miles... A lash cap is a band aid... |
HAM Inc |
Jun 4 2008, 08:09 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Yep, loose valve adjustment, and or poor oil. Swivel screws would have prevented this problem, and the excessive guide wear that usually accompanies tip wear.
If you want to stretch the service interval, the lash caps will serve as a sutiable band aid. Make sure you replace the valve adjusters at that time, and you will almost certainly need to shim the rockers to account for the lash caps, unless your adjusters are wound in to deal with cam wear. |
brer |
Jun 4 2008, 10:49 AM
sean_v8_914 |
Jun 4 2008, 11:24 AM
yup, bandaids have their place. I'm a "do it right" kind of guy but i look at cost-benefit. I would prefer a rebuilt head but the banbaid might get you down the road happy for another year.
Lo-Fi Version | Time is now: 15th May 2024 - 01:52 PM |
