kconway
Jun 3 2008, 07:25 PM
I'm changing out the pushrod tubes and seals and found this. Do I need to replace this valve?
Kev
BarberDave
Jun 3 2008, 07:33 PM
Absolutely...... YES......... Dave
PeeGreen 914
Jun 3 2008, 07:34 PM
Yes. You want it to be a nice smooth flat surface.
BarberDave
Jun 3 2008, 07:38 PM
All of them ........ Dave
SLITS
Jun 3 2008, 07:39 PM
To save the valve, you could have the tip machined flat and use a lash cap.
BarberDave
Jun 3 2008, 07:44 PM
I would throw away all of them and the rockers, change just 1 and next week
others will go. Matter of fact I would have a good head shop ,( Len's ) rebuild
them. Dave
BarberDave
Jun 3 2008, 07:48 PM
SLIT"S Wouldn' t machineing the valve remove the heat treat makeing it to
soft even for a lash cup to last very long? Dave
kconway
Jun 3 2008, 07:49 PM
Can someone explain to me what the likely cause is. Car ran fine. Need a cheaper solution to rebuilding the entire head and pretty sure I'm not the guy to do it. Can I take the whole head to RIMCO or do they just do the machining?
Just like peeling an onion...
ericread
Jun 3 2008, 08:56 PM
Nah, You can buff that out.
SLITS
Jun 3 2008, 09:14 PM
QUOTE(BarberDave @ Jun 3 2008, 06:48 PM)
The lash cap is hardened and fits over the tip of the valve. The hardened surface takes the sliding of the rocker tip otherwise the rocker tip would "dig" into the malable surface and "mushroom" the stem tip.
Didn't say it was the way to go, but it is one way.
Allan
Jun 3 2008, 10:53 PM
QUOTE(kconway @ Jun 3 2008, 06:49 PM)
Yes
brer
Jun 3 2008, 11:17 PM
You can get it done right here in san diego. Better than RIMCO by a mile.
Around 600+/- for the pair, if no welding. Thats a rebuild.
kconway
Jun 3 2008, 11:20 PM
QUOTE(brer @ Jun 3 2008, 09:17 PM)
You saying they would replace all the valves, springs, rockers in both heads for ~$600? Whats the place your speaking of?
sean_v8_914
Jun 3 2008, 11:21 PM
if the engine is assembled and still in the car...and you don't want to drop it all, put lash caps on all 4 valves and drive it till she spits chunks
kconway
Jun 3 2008, 11:22 PM
QUOTE(sean_v8_914 @ Jun 3 2008, 09:21 PM)
Its out on an engine stand.
brer
Jun 3 2008, 11:49 PM
QUOTE(kconway @ Jun 3 2008, 10:20 PM)
don bolton
Bugpatch 619-449-8670
thats just ballpark, you would have to talk to him about what NEW parts you want, and how bad your heads are of course.
Jake Raby
Jun 3 2008, 11:54 PM
Brer,
I never knew that was the "don" you were referring to...
As far as that valve, well its a classic example of a valve that was ran loose for many miles... A lash cap is a band aid...
HAM Inc
Jun 4 2008, 08:09 AM
Yep, loose valve adjustment, and or poor oil. Swivel screws would have prevented this problem, and the excessive guide wear that usually accompanies tip wear.
If you want to stretch the service interval, the lash caps will serve as a sutiable band aid. Make sure you replace the valve adjusters at that time, and you will almost certainly need to shim the rockers to account for the lash caps, unless your adjusters are wound in to deal with cam wear.
brer
Jun 4 2008, 10:49 AM
QUOTE(Jake Raby @ Jun 3 2008, 10:54 PM)
Brer,
He's a great guy Jake.
Honest as they come.
sean_v8_914
Jun 4 2008, 11:24 AM
yup, bandaids have their place. I'm a "do it right" kind of guy but i look at cost-benefit. I would prefer a rebuilt head but the banbaid might get you down the road happy for another year.
kconway
Jun 4 2008, 08:55 PM
Pulled the head off the one side...both exhaust valves stems are damaged the one photo above is the worst of it. Intake valve stems look okay.
I appologize if this is boring or remedial but I've never been in an engine this far before. Does anything look way abnormal in these photos? This is cylinders 1 & 2.
Kev
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
Joe Bob
Jun 4 2008, 10:34 PM
Dude, you need to pull the valves, look for damage to the stems and seats. Not a job for the newbie....
You have the heads off, best to take it to or ship them to reputable AIR cooled head shop....
You're in So Cal....RIMCO.
http://www.rimcovw.com/
Joe Bob
Jun 6 2008, 09:41 AM
QUOTE((*)(*) @ Jun 4 2008, 08:34 PM)
http://www.rimcovw.com/Hmm, based on some follow-up posts, don't use RIMCO....my bad...
It's been awhile...geez, 15 years since I used them.
brer
Jun 6 2008, 10:22 AM
RIMCO will not be here long anyway.
fixtures and machines are for sale, $460,000 i hear.
Property will be sold off for development.
bye RIMCO
