Upgrading to 911 swivel feet, what mods are required? |
benalishhero |
Jun 6 2008, 06:39 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Hey guys:
I'm looking to purchase 911 swivel feet for my 2.0. What modifications, if any, should I anticipate? TIA Cheers! |
type47 |
Jun 6 2008, 06:48 PM
all i know is that the swivel feet require an (?) 8mm (7mm?) rocker as used in the early 1.7's as the later rockers are 10mm.
SLITS |
Jun 6 2008, 06:49 PM
1.) A set of 1.7/1.8 rockers
2.) Machine work to remove at least 0.060" off the screw adjustor end. |
type47 |
Jun 6 2008, 06:53 PM
... even my 1.8's were 10mm
SLITS |
Jun 6 2008, 06:56 PM
Ok, I'll revise it then 'cause I've seen 8mm on a 2.0
Get a set of rockers with 8mm adjustor screws! |
benalishhero |
Jun 6 2008, 07:05 PM
Do you mean shorten the new adjuster scews .060" on the threaded side. I'm assuming they will hit the V/C if I don't. The earlier rockers aside, Is this the only other mod? |
Cap'n Krusty |
Jun 6 2008, 07:32 PM
The machining is done to the underside of the rocker arms, the side nearest the valve, to allow clearance for the thick swivel portion of the adjuster screw.
BTW, why do you call this an "upgrade"? The Cap'n |
benalishhero |
Jun 6 2008, 07:37 PM
Good question. I'm assuming it quiets the valves.? |
Cap'n Krusty |
Jun 6 2008, 08:27 PM
No, not really. Clearance is clearance, and the clearance makes the noise. Besides, that, what in "quiets the valves" is an "upgrade"? If that's an upgrade, then hydraulic lifters would be an upgrade, despite the loss of power associated with that conversion.
The Cap'n |
VaccaRabite |
Jun 6 2008, 08:52 PM
I would not bother with this unless you are also upgrading your cam, lifters, rest of your valve train.
Zach |
Borderline |
Jun 6 2008, 10:08 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
The machining is done to the underside of the rocker arms, the side nearest the valve, to allow clearance for the thick swivel portion of the adjuster screw. BTW, why do you call this an "upgrade"? The Cap'n Cap'n: I take it by your tone that you don't consider this an upgrade? Would you care to enlighten us? I figured that anytime you could put on a 911 part it must be an upgrade. Also, the flat surface of the swivel adjuster would mate better with the top of the valve stem giving a little less friction as opposed to the point contact of the standard adjuster screw. Now that I think about it, the 911 swivel would not cause the valve to rotate as it slides across the stem. hmmm? (IMG:style_emoticons/default/confused24.gif) |
Cap'n Krusty |
Jun 6 2008, 11:47 PM
You just answered your last question. Now, for the bad news. The premise "I figured that anytime you could put on a 911 part it must be an upgrade." prompts me the say "WHAT!"? Gonna throw a couple of extra spark plugs in there? Maybe some 911 seats? They don't fit, but "what the hell, they're 911" makes it good? Little duct tape and we're good to go ........ Gimme a break. Just 'cause they fit your big brother (or maybe your big sister) doesn't mean they're right for you ................. I could run with that, but I'm not that drunk. Yet.
The Cap'n |
rhodyguy |
Jun 6 2008, 11:53 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
testy tonight.
benalishhero |
Jun 7 2008, 12:14 AM
So, to review, there are no advantages to switching to the swivel type adjusters? Are there any disadvantages? Besides cost and machining?
VaccaRabite |
Jun 7 2008, 07:51 AM
There are advantages, once you start improving other aspects of your valve train.
I can't think of any disadvantages, other then cost. |
benalishhero |
Jun 7 2008, 03:29 PM
Vacca Rabite- Thank you.
roadster fan |
Jun 7 2008, 04:20 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Ok i will bite. What are the advantages to the swivel feet once you start changing the other parts in the valve train? Easier to set geometry? Complete aircooled novice, so go easy on me.
Jim |
VaccaRabite |
Jun 7 2008, 06:49 PM
Lighter weight, stronger, and better engagement of the valve stem.
On a stock application, it is just overkill. On a hotter cam with bigger valve springs, you need it. It is not something that will give you more HP, it will just let your engine last longer using other hotter parts. Zach |
Lo-Fi Version | Time is now: 14th May 2024 - 01:09 AM |
