what thread size - for 3.90mm shaft, i want to install a swivel linkage |
jimkelly |
Jun 8 2008, 03:29 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i guess one of these four??
http://www.jegs.com/i/JEGS/555/15730/10002/-1 http://www.jegs.com/i/JEGS/555/15734/10002/-1 http://www.jegs.com/i/JEGS/555/15740/10002/-1 http://www.jegs.com/i/JEGS/555/15729/10002/-1 thanks jim (IMG:style_emoticons/default/smoke.gif) Attached image(s) |
sww914 |
Jun 8 2008, 04:16 PM
I think that you should be able to thread the end of the accel. cable to screw into the linkage. I found this chart- http://www.hamuniverse.com/antfrac.html
It looks like 3.9mm is very close to 10/32 which I believe is a #10 screw so you could run a die over the cable end and thread it right into the linkage with the #10 threads. You'll need a locknut on that, too. |
jimkelly |
Jun 8 2008, 08:33 PM
ok - went to autozone and got me a $23 tap and die set - i tapped the cable end and got it installed semi half assed for now. and for now to me usually means until something breaks.
Lo-Fi Version | Time is now: 15th May 2024 - 12:02 PM |
