I think that you should be able to thread the end of the accel. cable to screw into the linkage. I found this chart- http://www.hamuniverse.com/antfrac.html It looks like 3.9mm is very close to 10/32 which I believe is a #10 screw so you could run a die over the cable end and thread it right into the linkage with the #10 threads. You'll need a locknut on that, too.
jimkelly
Jun 8 2008, 08:33 PM
ok - went to autozone and got me a $23 tap and die set - i tapped the cable end and got it installed semi half assed for now. and for now to me usually means until something breaks.
