clutch and throttle cables, tangled somehow ?? |
jimkelly |
Jun 8 2008, 04:44 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
when i step on the clutch - my rpm changed slightly for a split second and i can feel a click at the peddle - i have them interacting with each other ??
any ideas? jim |
Jun 8 2008, 05:19 PM
This is a very common problem.
Use a mirror and remove the front tunnel cover. The accel cable is looped once over the clutch cable. The issue is in front of the shifter... If you use a mirror from the front, you can see it. The fix is to unclip the accel cable and using long things like coat hangers or whatever you can...unloop it. I take out the shifter also...its alot easier to look from the mirror up front, but reach in from the shifter side... Rich |
ericread |
Jun 8 2008, 05:27 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
This is a very common problem. Use a mirror and remove the front tunnel cover. The accel cable is looped once over the clutch cable. The issue is in front of the shifter... If you use a mirror from the front, you can see it. The fix is to unclip the accel cable and using long things like coat hangers or whatever you can...unloop it. I take out the shifter also...its alot easier to look from the mirror up front, but reach in from the shifter side... Rich (IMG:style_emoticons/default/agree.gif) I went through this myself about a month ago... Time to get to know your tunnel really well (IMG:style_emoticons/default/headbang.gif) |
vesnyder |
Jun 8 2008, 05:37 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I struggled with this problem for a while. In my case my engine would spike when I pushed in the clutch. Not only were the cables intertwined but I was also getting interference at the end of the cables. What a PIA. Good luck!
jimkelly |
Jun 8 2008, 08:00 PM
thanks guys : )
jim |
jimkelly |
Jun 8 2008, 08:28 PM
luckily my front cover is always off and i roll with no carpeting at all - i looked in with a mirror and small light and can easily see the twist - i popped off the throttle cable at the peddle assy bell crank - looped it under the clutch cable and reconnected it to the bell crank - all is good now - thanks - jim
ericread |
Jun 8 2008, 08:32 PM
Glat it worked out so easy for you (IMG:style_emoticons/default/smilie_pokal.gif)
So what's with your big honkin picture in each post? Are you selling Real Estate or do you think you're pretty or somthin? (IMG:style_emoticons/default/laugh.gif) |
jimkelly |
Jun 8 2008, 09:07 PM
that is funny - i just started selling real estate and am using this old pic : ))
but i posted the pic hoping others would follow - as it would be nice to be able to put a face with a name. ok - i will put up a more recent and more grease-under-fingernails pic up instead : )) Glat it worked out so easy for you (IMG:style_emoticons/default/smilie_pokal.gif) So what's with your big honkin picture in each post? Are you selling Real Estate or do you think you're pretty or somthin? (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 07:07 PM |
