QUOTE(r_towle @ Jun 8 2008, 04:19 PM)
This is a very common problem.
Use a mirror and remove the front tunnel cover.
The accel cable is looped once over the clutch cable.
The issue is in front of the shifter...
If you use a mirror from the front, you can see it.
The fix is to unclip the accel cable and using long things like coat hangers or whatever you can...unloop it.
I take out the shifter also...its alot easier to look from the mirror up front, but reach in from the shifter side...
Rich
I went through this myself about a month ago...
Time to get to know your tunnel really well
