post pics!, 914's on Trailers |
messix |
Jun 9 2008, 04:13 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i make a loop [or double back] and stick the loop thru the wheel, then hook the loop to the end hook and pull the strap tight. hard to explain but easy to see.
this won't abriad the strap when done right. |
Joe Bob |
Jun 9 2008, 04:15 PM
Either use the eyebolts that screw onto the lugs or straps that have a cradle that go around the tire or LAST choice, attach to the body. Rusty 914s have rusty front hooks.... (IMG:style_emoticons/default/dry.gif)
You WANT the normal suspension to flex and move and the tires tight as well as the straps. Putting a stap over an edge is an invitation to rubbing, especially if any one has a less than optimum tightness..... You don't want anything that can rub on your straps moving. They also make cheap looped straps that have eyebolts on each end. They can make a loop and then you attach the more expensive tie downs to that.... |
stateofidleness |
Jun 9 2008, 04:19 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
One strap through each wheel. Unfortunately I had one strap too tight and the little movement that the car did make, shred the strap halh way through. Now I need a new strap. Next trip will have a pad behind the strap. I think they were 20 foot strapswhen I bought them, but I cut 'em. (IMG:http://i128.photobucket.com/albums/p183/glstrojan/PICT2301.jpg) this looks like what i may do.. seems to be the safest each tire to it's own corner of the trailer. handbrake set as well rethinking the 20'ers now lol.. may have to make a harbor freight run (IMG:style_emoticons/default/smile.gif) thanks for the pics |
sww914 |
Jun 9 2008, 04:20 PM
Here's my $50.00 princess. You can't see the straps but I have 2 hooks in the back that go to the motor mount bosses and 2 ratchet straps in the front that go to the control arms.
Believe it or not there's no rust in the longs, none in the hell hole, none in the floors, just a little in the rear trunk. Attached thumbnail(s) |
sww914 |
Jun 9 2008, 04:21 PM
This is what happen when some bonehead strips the car to bare metal and doesn't use epoxy primer.
stateofidleness |
Jun 9 2008, 04:41 PM
guess ill add another dumb question here..
is it safe to roll the car with the cv axles still connected? i have them "suspended" so that they wont rub on the inside of the trailing arm and can still spin, i just wanna make sure before i move it so i dont break anything hopefully, HOPEFULLY the car will be on the trailer by tomorrow evening and will be in the body shop by the weekend!! |
Joe Bob |
Jun 9 2008, 04:44 PM
I wouldn't tow with the axles flopping around....but it's OK to push it around or roll it onto a trailer.
Eric_Shea |
Jun 9 2008, 04:45 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE im tryin to see the best way to strap it down I really like the tire nets. I had those on a friends trailer. I pulled my 914 back from SF using those on the front. Fairly inexpensive if I recall. |
Eric_Shea |
Jun 9 2008, 04:47 PM
QUOTE This is what happen when some bonehead strips the car to bare metal and doesn't use epoxy primer. Fiberglass can and should replace all of that (IMG:style_emoticons/default/biggrin.gif) |
dw914er |
Jun 9 2008, 04:54 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
I wouldn't tow with the axles flopping around....but it's OK to push it around or roll it onto a trailer. (IMG:style_emoticons/default/agree.gif) |
jonferns |
Jun 9 2008, 04:58 PM
How big of a trailer? Heres when ours was shipped from CA
sww914 |
Jun 9 2008, 05:08 PM
QUOTE This is what happen when some bonehead strips the car to bare metal and doesn't use epoxy primer. Fiberglass can and should replace all of that (IMG:style_emoticons/default/biggrin.gif) Our friend Roger wants to help with that. (IMG:style_emoticons/default/smile.gif) www.ultimate914.com |
PeeGreen 914 |
Jun 9 2008, 05:23 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
QUOTE This is what happen when some bonehead strips the car to bare metal and doesn't use epoxy primer. Fiberglass can and should replace all of that (IMG:style_emoticons/default/biggrin.gif) Our friend Roger wants to help with that. (IMG:style_emoticons/default/smile.gif) www.ultimate914.com (IMG:style_emoticons/default/piratenanner.gif) Shoot, my stuff looks good and I want him to do stuff on mine (IMG:style_emoticons/default/biggrin.gif) but I want to stay married too (IMG:style_emoticons/default/blink.gif) |
stateofidleness |
Jun 9 2008, 05:45 PM
just towin it up the street about 2 miles to the body shop
i dont think theyll be "flopping" around, theyre suspended with huge zip ties and dont have much travel room other than spinning |
Joe Bob |
Jun 9 2008, 05:50 PM
Probably cool...but CVs are an ignored service REQUIRED part. Best to pull, inspect. regrease and re-seal....BOTH inners and outers. Good time to do it.....
Eric_Shea |
Jun 9 2008, 05:58 PM
Z speaks of logic. Must be the meds have kicked in! (IMG:style_emoticons/default/ohmy.gif)
Jun 9 2008, 07:33 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
dont roll the car, or set any wieght on the rear without the inner hub in place...the male portion of the CV joint.
If you can, remove the whole axle, take the male end off and put that back in the hub...then you can service the CV joints while you wait. As far as towing on a trailer, always cross your straps to prevent side to side jumping of the car...straight strapping will not survive and the car will hop...seen it on show cars, in closed trailers... This is simple logic....cross the straps. Rich |
BMartin914 |
Jun 9 2008, 07:39 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Spotted this little gem in the mountains outside of Pagosa Springs, CO
(IMG:http://i74.photobucket.com/albums/i245/bhmartin2025/Pagosa_NJ_trailer_car.jpg) |
URY914 |
Jun 9 2008, 08:02 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,983 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
URY914 |
Jun 9 2008, 08:04 PM
Lo-Fi Version | Time is now: 4th June 2024 - 04:49 AM |
