914 air conditioning, What to do folks? |
dilde |
Jun 12 2008, 05:45 PM
Newbie Group: Members Posts: 33 Joined: 29-March 05 From: Los Angeles, CA Member No.: 3,843 |
Hey guys & gals,
The York compressor in my '73 2.0 has finally died. I have already changed out the hoses previously to "barrier?" hoses which run 134a freon. I can get another rebuilt York I suppose, but I have heard of rotary compressors working better and using less hp to run. Has anyone already made the changeover? Are there any rotary compressors that fit properly? Do I need mounting brackets? Any info would be greatly appreciated. I live in So. Cal and gas is $4.65 as of today, which means the 914 will be on the road more than the F-150. And it's getting hot here! Scott |
Joe Owensby |
Jul 30 2008, 10:18 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Did you have to have any idler pulleys with this last set up? I have adapted a Sanden compressor to a York Mount that came with a parts car. This adapter had a small idler pulley that ran under the bottom side of the belt, just inside the compressor. I assumed this was needed to provide clearance, but was wondering from your photos if it was really needed. I plan to rework my mount the next time I have to remove the engine, to something similar to what you have, as it looks to be much easier to adjust the belt tension. Thanks for sharing the photos. JoeO
Lo-Fi Version | Time is now: 17th May 2024 - 06:18 PM |
