dilde
Jun 12 2008, 05:45 PM
Hey guys & gals,
The York compressor in my '73 2.0 has finally died. I have already changed out the hoses previously to "barrier?" hoses which run 134a freon. I can get another rebuilt York I suppose, but I have heard of rotary compressors working better and using less hp to run. Has anyone already made the changeover? Are there any rotary compressors that fit properly? Do I need mounting brackets?
Any info would be greatly appreciated. I live in So. Cal and gas is $4.65 as of today, which means the 914 will be on the road more than the F-150. And it's getting hot here!
Scott
McMark
Jun 12 2008, 07:56 PM
A more helpful parts store might have a picture/spec book for compressors that you could look through and find something. Or, you can search for other cars which used that same unit and see if someone else found anything. That compressor is not a 914 specific part, so it was undoubtedly used on other cars. Or there is always the idea of making an adapter plate.
I was just thinking about this today, and had a brainstorm. Run fluid lines inside of the seat upholstery, run a tiny A/C setup that will cool a fluid tank instead of cooling air, then pump the chilly fluid through the seats. I would think that the size of the A/C system would be very small. Maybe even small enough to run an electric compressor...
TravisNeff
Jun 12 2008, 08:06 PM
That's a pretty crafty idea
draperjojo
Jun 12 2008, 08:29 PM
You could check with these guys
http://www.iceac.com/germanproducts.htmlor call..........come on Dave, just say it........that one auto place down there in Marietta..............
LvSteveH
Jun 12 2008, 08:30 PM
There's always option "B"
ericread
Jun 12 2008, 08:35 PM
How about just hooking it up to a cool shirt!
Click to view attachmentSorry, air conditioning is not the same as a cold seat.
As for myelf, I take off the targa top and open the windows.
computers4kids
Jun 12 2008, 08:36 PM
I bought a new Sanden508 off an ebay auction that runs on R134 and a new adapter plate that is made specially to bolt the 508 to the York bracket. Cost for the two with shipping was $200.
Now that I've gone to a v-8, I'm not to sure I will be using the parts.
dilde
Jun 12 2008, 11:41 PM
Thanks guys, especially for the laughs. I know there has to be a better way than just rebuilding the York.
Computers4kids, thanks. I knew I came to the right place.
Any other suggestions welcomed.
hcdmueller
Jun 13 2008, 01:23 AM
Computers4kids, if you decide to get rid of the compressor setup PM me. I was debating tearing out my AC but lately it seems better to keep it.
Gint
Jun 17 2008, 05:27 PM
QUOTE(LvSteveH @ Jun 12 2008, 07:30 PM)
What is that Steve?!?!
McMark
Jun 17 2008, 08:01 PM
Power Inverter + home A/C unit.
davep
Jun 17 2008, 10:47 PM
I know about a spare condenser that is available.
LvSteveH
Jun 18 2008, 12:24 AM
QUOTE(Gint @ Jun 17 2008, 04:27 PM)
McMark nailed it. I simile whenever I see that pic.
maf914
Jun 18 2008, 09:52 AM
The adapter bracket in Computers4kids post is available for $45 on e-bay.
http://cgi.ebay.com/ebaymotors/York-to-San...emZ190138009435I just wonder if it fits the York bracket used for the 914 A/C kits used by the dealers and how the Sanden compressor fits relative to the big York. I would like to know how much engine sheet metal needs to be cut or reshaped. I guess you just have to give it a shot....
computers4kids
Jun 18 2008, 10:54 AM
QUOTE(maf914 @ Jun 18 2008, 08:52 AM)
Here's one install...not mine. I've seen it done without cutting the shelf as well.
maf914
Jun 20 2008, 08:26 AM
Mark, Thanks for the photo. Looks like the engine tin still needs to be cut quite a bit. That is a clean engine compartment!
thomasotten
Jul 30 2008, 01:24 PM
Is this adapter all that is needed to bolt to the fan shroud, or do you need the old bracket as well? I'm confused.
computers4kids
Jul 30 2008, 01:37 PM
QUOTE(thomasotten @ Jul 30 2008, 12:24 PM)
The adapter from ebay bolts to part of the York bracket...you need both.
JRust
Jul 30 2008, 02:15 PM
That is flippin hilarious
JmuRiz
Jul 30 2008, 04:07 PM
QUOTE(computers4kids @ Jun 18 2008, 08:54 AM)
Here's another link I got for a York to Sanden bracket from a Mercedes site I visit, you may check with this company about it:
southernmost914
Jul 30 2008, 06:34 PM
Photo of same brackets and Sanden 505:
attachmentid=152028]
jjs3rd914
Jul 30 2008, 09:48 PM
I too used a York to Sanded adapter on a DPD system which we converted to 134a. We modified the brackets to allow for an easier adjustment and less hardware. All new barrier hoses were used with the new compressor. The system works great with 40 deg. vent temperatures at higher RPM. Only problem is engine is a 1972 1.7L and not a lot of HP. Had to rig up an additional air valve to get more air on idle as car would die from the load.
Hope the picture help.
jjs3rd914
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
Joe Owensby
Jul 30 2008, 10:18 PM
Did you have to have any idler pulleys with this last set up? I have adapted a Sanden compressor to a York Mount that came with a parts car. This adapter had a small idler pulley that ran under the bottom side of the belt, just inside the compressor. I assumed this was needed to provide clearance, but was wondering from your photos if it was really needed. I plan to rework my mount the next time I have to remove the engine, to something similar to what you have, as it looks to be much easier to adjust the belt tension. Thanks for sharing the photos. JoeO
bandjoey
Jul 30 2008, 11:15 PM
And then there's Option C
bandjoey
Jul 30 2008, 11:18 PM
Seriously...here's a shot of body work up front where the condensor goes..This is the strongest and cleanest setup I've seen...not mine, but getting ready to do mine this way.
jjs3rd914
Jul 31 2008, 08:59 PM
QUOTE(Joe Owensby @ Jul 30 2008, 08:18 PM)
If you notice we did not even use the York bracket to which the Sanden adapter was to mount. We just drilled a couple of extra holes on the adapter itself and made the slotted adjustment pieces. Yes our original York mount had a idler pulley. On this new setup we had to slightly modify the oil cooler bracket for clearance, but otherwise no other mods for the belt to clear. It took several attempts to finally get the right belt length for proper adjustment. By eliminating the York bracket we also saved some weight and space.
In a later post there is a picture of the front truck reinforcement frame. We also did the same thing and welded in a 1/2" square tubing frame to "fix" the hack job the dealer had done when the car was new.
About the only other upgrade we might do in the future to the stock DPD system is to replace the original fan and motor on the condensor with a "SPAL" multi-blade fan for more air flow.
jjs3rd914
Joe Owensby
Jul 31 2008, 09:15 PM
Thanks for the info. This will be a big help when I clean up my installation. JoeO
r_towle
Jul 31 2008, 09:20 PM
How is the belt run on these systems???
Rich
Joe Owensby
Aug 19 2008, 11:01 PM
The aftermarket system on my parts car had a small (maybe 6" diameter) pulley located behind the cooling fan. It replaced the washer/spacer behind the fan. the belt runs out the passenger side of the car, just in front of the oil cooler. Mine had a small idler pulley just below the pulleyon thecompressor. I am not sure if this was to tension the belt, or to raise it a little for clearance purposes. It actually contacted the "V" belt on the outer surface and raised the belt up a little. JoeO
jdamiano
Feb 3 2019, 06:18 PM
For anyone using this for reference as I did. My car has the VPC system. I got a Sanden 505 and York to Sanden bracket. I had to cut a slot in the bracket to make it work but it put the pulley almost in the exact same location. I got the stock size belt to fit but it is tight with none of the adjustment spacers installed. I would have purchased a one inch longer belt had I known. Now I just need to replace the hoses and charge the system.
jdamiano
Feb 3 2019, 06:29 PM
Oh and another thing I learned. I noticed the bracket connected to the engine was loose when I was taking things apart. I thought the nuts were just loose but it was there were rubber bushings that completely disinagrated. I was able to use some rubber hose to replace them.
jdamiano
Feb 3 2019, 08:24 PM
Here is the belt I used. It worked but was tight.
Superhawk996
Feb 7 2019, 04:19 PM
tmessenger
Feb 7 2019, 08:07 PM
Unfortunately, moisture in the air condenses when temperatures drop below the dew point. This means you end up with the wet seat literally, you need an evaporator coil in a box with a drain to carry condensate out of the cars interior.
Tim
QUOTE(McMark @ Jun 12 2008, 07:56 PM)
ejmetz
May 21 2019, 11:17 AM
Has anyone used the 914 retrofit system from Classic Auto Air? Would love to see a pic of the installation.
https://www.classicautoair.com/shop/1975-po...tioning-system/
dr914@autoatlanta.com
May 21 2019, 12:01 PM
we are about to do two 914 installations in the next two weeks
QUOTE(ejmetz @ May 21 2019, 10:17 AM)
Literati914
May 21 2019, 04:00 PM
QUOTE(ejmetz @ May 21 2019, 12:17 PM)
https://www.classicautoair.com/shop/1975-po...tioning-system/Don't know if you realized it, but the link (that you added) has TWO pictures and the second one shows it installed in a 914. Hopefully someone else will show us another install, for variety..
For me - I wish all the venting wasn't on the passenger's side.
Amphicar770
May 21 2019, 06:30 PM
