Mallory Unilite and VDO oil pressure sender, don't fit together. Other options? |
VaccaRabite |
Jun 21 2008, 03:21 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, my 2056 has a Mallory Unilite. I wanted to add an oil pressure guage, so I hopped over to Pelican and bought the VDO gauge and sender. the sender had contacts for both the the oil light and the sender.
After taking the tin off the 3/4 back to install, I figure out that the VDO sender won't fit with the Mallory in place, they are just too big. Will the sender that does not also support the oil light allow both the Unilite and the VDO sender to fit? Or is the sender case the same size, but with just 1 terminal? Is there another sender that will work, fer sure? Zach |
Lo-Fi Version | Time is now: 19th May 2024 - 06:06 AM |
