stripped case |
stripped case |
DarrenG |
Jun 25 2008, 12:53 PM
Newbie Group: Members Posts: 46 Joined: 20-May 08 From: Liberty, MO Member No.: 9,078 Region Association: Upper MidWest |
I have an oil leak from the case bolt that runs in the middle of, and a little below, the push rod tubes. This is the bolt that runs through the oil tube. The case is stripped.
Does anyone have a good recommendation for repairing this? It's pretty deep (8 x 88mm bolt). Do I have to split the case? I would prefer not to because the flywheel and fan hub are still attached. If I do have to split the case, will I need to replace the engine bearings? Or can these be reused? They were recently installed - just a few hundred miles on the rebuild. Thanks D |
Lo-Fi Version | Time is now: 27th May 2024 - 06:36 PM |
