What Rim size w/ GT Flares, Help a flare newbie out |
jmill |
Jun 27 2008, 04:55 PM
Looking at purchasing some 5 lug rims. What is the best rim and tire size for steel GT Flares? I know most folks run w/ spacers. Please let me know spacer size too.
Todd Enlund |
Jun 27 2008, 05:17 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I'm shopping too (IMG:style_emoticons/default/biggrin.gif)
I'm doing a 5 lug conversion, and hope to run 7s and 8s. Fit is also dependent on offset... early offset (23mm) wheels will need less spacer, if any, than late. If you plan on aggressive driving, or racing, you also need to watch the scrub angle on the fronts... bad scrub angle will make your fronts fight each other and you lose grip. I haven't done the calculations on that one yet, but I'm sure that 7s can be setup properly, not sure about 8s. Tire size... overall diameter will affect your effective gear ratio. Width is dependent on wheel width and clearance. How you plan on driving the car will make a difference in your selection. |
dr914@autoatlanta.com |
Jun 27 2008, 05:22 PM
914 Guru Group: Members Posts: 7,873 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
jmill |
Jun 27 2008, 05:25 PM
With the GT flare group buy going on there is going to be at least 10 of us shopping. It's going to be a good time to sell some 5 lug rims. (IMG:style_emoticons/default/biggrin.gif)
I was hoping to beat the rush and pick some up before the rest of the fellas. My main concern is that they fill up the fenders. I'm going to drive it hard. Rubbing can't happen. |
PeeGreen 914 |
Jun 27 2008, 05:40 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I'm running 15x8s with a 1"spacer in the rear. Tires are 225 50 r15 Toyo RA1s. No rub.
JRust |
Jun 27 2008, 10:50 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I've got a set of 993 wheels. They are 7x16 front's & 16x8's for rear. Right now I have the 17x7's on the rear with a 1"spacer. 8's were to big with stock body. Once I flair I will be putting the 8's on the rear. Probably be closer to a 2" spacer but we will see. My 1.5" spacer doesn't look like it's enough. Won't know till I come up with the dough for my flares (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 27th May 2024 - 08:58 PM |
