| mattp |
Jun 27 2008, 08:34 PM
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I put the engine and transmission back in car but transmission is in gear regardless of shifter?
How can I make sure shifter and transmission are in sync without starting car? (new engine need to break it in) Thanks, Matt |
| Bartlett 914 |
Jun 27 2008, 10:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I put the engine and transmission back in car but transmission is in gear regardless of shifter? How can I make sure shifter and transmission are in sync without starting car? (new engine need to break it in) Thanks, Matt Disconnect shifter near the shifter and put the tranny in neutral at the tranny |
| Dr. Roger |
Jun 27 2008, 10:38 PM
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
I put the engine and transmission back in car but transmission is in gear regardless of shifter? How can I make sure shifter and transmission are in sync without starting car? (new engine need to break it in) Thanks, Matt Disconnect shifter near the shifter and put the tranny in neutral at the tranny you'll see the disconnect shifter thing under the carpet at the red arrow. Attached image(s)
| rhodyguy |
Jun 28 2008, 12:11 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you mean to say you can't engage any of the gears at all? can you have someone work the shifter while you go under the car to see what's going on?
k |
| mattp |
Jun 28 2008, 09:29 AM
the car is in gear, I dont know which one (other than NOT reverse) when I connect the shifter it will not go into 2nd or 4th or reverse (top of shift pattern)
I also cant seem to get it out of gear by disconnecting shift rod (at bulhead) and moving it around. any help would be great. |
| rhodyguy |
Jun 28 2008, 09:37 AM
try moving the coupler on the bottom of the shift lever forward forward on the front rod (lenghtening the whole assem). freeplay should be the roughly the same, while in engaged r/2/4 plane and the 1/3/5 plane. mark the point on the front of the front rod where it's currently at with a fine tip sharpie so you can gauge how great of an adj you make. adj accordingly.
push the clutch pedal in. k |
| mattp |
Jun 28 2008, 10:01 AM
I'm sorry, I do not understand you. Let me take a shot: reconnect shifter rod at bulkhead, disconnect shifter adjustment under the rug at the shifter,
then reconnect when transmission is in neutral and shifter is in neutral? How do I get transmission in neutral? |
Lo-Fi Version | Time is now: 7th December 2025 - 10:29 PM |
