Okay, What's the deal?, Car starts and idles when cold, but dies when warm? |
montoya 73 2.0 |
Jun 27 2008, 09:38 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
It won't idle after it warms up and won't start immediatley either. I have to wait a little while and it will start. When it does start, if I give it gas it wants to die. Help me please. It had been on jackstands for the last 3 years and I finally got it going again and now this. (IMG:style_emoticons/default/WTF.gif)
orange914 |
Jun 27 2008, 10:01 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
does it feel flooded or oil have gas in it? check the cold start valve for leakage. maybe aux. valve or cracked old vacuum lnes leaking
mike |
montoya 73 2.0 |
Jun 27 2008, 10:10 PM
i'll check the cold start valve. not flooded, vacuum lines new, need to check the gas in the oil thing. what do i do if there is gas in the oil?
orange914 |
Jun 27 2008, 10:13 PM
championgt1 |
Jun 27 2008, 11:45 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
If it has been sitting for 3 years replace the fuel filter, drain the tank, and put new gas in. You might have a clogged fuel filter or clogged fuel sock in the tank.
scotty914 |
Jun 27 2008, 11:52 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
how about the cht. my 1.8 did that too. try starting it then grounding the sensor line. it will run leaner when grounded but it will run.
edit some times they just get loose when the head warms, try snuging it down before you replace if grounding it works |
montoya 73 2.0 |
Jun 28 2008, 11:16 AM
there is a slight smell of gas on the dipstick. do i just drain and refill or is this a bigger problem? What's a cht?
montoya 73 2.0 |
Jun 28 2008, 11:29 AM
Lo-Fi Version | Time is now: 20th May 2024 - 04:28 AM |
