Cracked CV Joint Bearing Cage |
tornik550 |
Jun 28 2008, 10:16 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I was removing my inner CV joints to change the boots and when I got the passenger side off and cleaned the grease I realized that the cage that holds the bearings in place was cracked. There are two cracks, one on each side of one of the openings that holds a bearing.
Does anybody know if this will cause problems? I would assume that it would. Does anybody know where I can get one of those parts? Thanks, Steve |
BMartin914 |
Jun 29 2008, 08:01 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
It will not work, the cage will no longer retain the balls correctly. The 914 joints are NLA as a new part.
Krieger |
Jun 29 2008, 10:59 AM
Advanced Member Group: Members Posts: 4,713 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Its junk and will leave you stranded. Someone here sells modified type 1 joints.
McMark |
Jun 29 2008, 01:59 PM
PMBPerformance. Eric_Shea.
jimtab |
Jun 29 2008, 06:01 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Rich has original porsche cv joints, a pile of them at 149.00 a pop.....that's Rich at HPH in Redwood City, Ca.
Lo-Fi Version | Time is now: 19th May 2024 - 04:38 PM |
