Full Version: Cracked CV Joint Bearing Cage
tornik550
I was removing my inner CV joints to change the boots and when I got the passenger side off and cleaned the grease I realized that the cage that holds the bearings in place was cracked. There are two cracks, one on each side of one of the openings that holds a bearing.
Does anybody know if this will cause problems? I would assume that it would. Does anybody know where I can get one of those parts?
Thanks,
Steve
BMartin914
It will not work, the cage will no longer retain the balls correctly. The 914 joints are NLA as a new part.
Krieger
Its junk and will leave you stranded. Someone here sells modified type 1 joints.
McMark
PMBPerformance. Eric_Shea.
jimtab
Rich has original porsche cv joints, a pile of them at 149.00 a pop.....that's Rich at HPH in Redwood City, Ca.
