| jesiv |
Jun 28 2008, 11:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
My front right-rear a-arm bushing has severe play! So I figure, I need to replace the bushings in my a arms. I have heard that stock rubber bushings are not available. But I think I saw some on the bird site. So as I try to decide what to do and find parts the problem festers... So what is the most obvious “upgrade”.. replace “all” the bushing, in the front end, koni shocks, front sway bar, turbo tie-rods. Currently the front end is stock no sway bar. What would you do?
Regards, James |
jesiv Front-End... A-ARM Bushings Jun 28 2008, 11:17 PM
r_towle Edited , just like the original post,
I give up...... Jun 28 2008, 11:19 PM
Phoenix 914-6GT Well, it really depends on your mechanical experie... Jun 28 2008, 11:52 PM
ejm
If you find anything to be bad replace it. As fo... Jun 29 2008, 05:35 AM
rhodyguy balljoints too. be done with it. if you don't ... Jun 29 2008, 12:36 PM
TeenerTim
balljoints too. be done with it. if you don't... Jun 30 2008, 12:35 PM
McMark FreeMotion Upgrade... ;)
Delrin are a suitable r... Jun 29 2008, 01:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:03 AM |
