What size webers for stock 2.0 litre?, I searched, i swear i did. |
james2 |
Jun 29 2008, 06:42 PM
Member Group: Members Posts: 97 Joined: 28-June 08 From: Georgia Member No.: 9,225 Region Association: None |
So my 73 has a pinto carb on it. i got it cranked today, but i'm not interested in playing with the single two barrel, did that on VW.
I'm thinking a set of 44IDFs would be nice, other option would be to hunt down the orginal EFI. I'm leaning towards the weber because i have experience with them. I have a set of 48 DRLA's, but I think they will be too big. |
db9146 |
Jun 29 2008, 07:05 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I had 44IDFs on a 2.0 I had back ing the '80s. Once it was jetted properly, it ran well. I also had a Bursch muffler and it sounded pretty good as well.
Jun 29 2008, 08:20 PM
if you are shopping, 40mm webers are better suited.
Rich |
rhodyguy |
Jun 29 2008, 08:26 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what's more important than the stamping on the side of the carbs is the size of the main venturi. for a stockish 2.0, 40s with 28mm vents work nicely. 44s with vent size reduced to 32 work well and are more adaptable to larger engines. on my engine, doing the size up with values noted seems to have resulted in more top end.
SGB |
Jun 29 2008, 10:04 PM
44's will be too big to plug & play. Use 40 idf with 28mm venturis, and tall intake manifolds and velocity stacks.
james2 |
Jun 29 2008, 10:14 PM
I spotted some nice 40 DRLA's on ebay. I believe they came stock with the 32mm venturis.
I just sold a set of 40's with 32 vents not long ago. Should have kept them. |
Jake Raby |
Jun 29 2008, 10:58 PM
40 IDF
32mm vents 130 mains 200 airs 55 idles f11 emulsion That will bolt on and run beautifully. 40 Dells are the best, they come stock with 34mm vents, 140 mains, 180 airs and a 60 idle :-) James, call me. |
Lo-Fi Version | Time is now: 8th May 2024 - 10:09 AM |
