Rear Camber Trouble |
7275914911 |
Jun 30 2008, 10:50 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Hey all,
got a little bowing outward of the back wheels. Is this camber as mention in title or something else going on? No spacers are on car. Is there a camber control in rear that can be adjusted or replaced? Thanks in advance for thoughts and ideas... jkp |
cobra94563 |
Jun 30 2008, 11:28 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
you can add/reduce camber by more/less shims under the outside rear control arm mount. Person in the vendor section sell shims - you can see what they look like.
blitZ |
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
The rear camber is adjusted using shims. It sounds you have a bit of negative camber, which is an aggressive setup for better cornering. My rear wheels bow out for the same reason. Are you having cornering problems?
Jeffs9146 |
Jun 30 2008, 11:29 AM
Yes, if you add shims your camber will change! While you are in there you should check the suspension ear hole and make sure it is not ovaled!
TeenerTim |
Jun 30 2008, 11:54 AM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
7275914911 |
Jun 30 2008, 01:23 PM
NO cornering issues at all.. (IMG:style_emoticons/default/w00t.gif)
Matter of fact it is on rails! I have drivin 6 to 8 different 914's (not that many I know) and none of them corner like this car. None of them had a 911 setup under the front end with 16x7(205/55) track tires all round either.. (IMG:style_emoticons/default/biggrin.gif) Was just concerned that I might have trouble back there. A PO was going to track race it so the setup could be very aggressive. I will look into the shimes because I want to drive it weekly with new tires but don't want to wear those tires out prematurely. Am going to purchase BFG G-Force for the street. Will also inspect sups. ear hole for ovaling. The rear looks fairly new tho. Thanks for all input jkp |
Lo-Fi Version | Time is now: 9th May 2024 - 11:43 AM |
