> how high does your car need to be, for a first time clutch job??
jsayre914
post Jun 30 2008, 06:28 PM
Speed Up !!!
im going to attempt my first clutch job, i did a search on floor jacks and stands and it was all about engine drops, i dont need to drop the engine i dont think. should i just get two sets of 3 ton floor jacks and use wood blocks with my current hydralic floor jack to get it up there. good enough??is that enough room??
I am learning as i go (IMG:style_emoticons/default/smile.gif)
Replies(1 - 9)
type47
post Jun 30 2008, 07:21 PM
Viermeister
well, you can just drop the transmission to do a clutch job but it's hard to say "how high". you just need it high enough to lay under the tranny (insert joke here) and muscle it (the transmission) off the engine and onto your chest. hopefully you've read the other posts about removing just the transmission, if not, search for some threads on that. support the rear of the engine with your jack stands and lower the trans slightly to enable the trans to have enough clearance of the bumper. trans weighs 80ish pounds.
post Jun 30 2008, 08:15 PM
Resident German
QUOTE(type47 @ Jun 30 2008, 05:21 PM) *
... muscle it off the engine and onto your chest ...
huh? (IMG:style_emoticons/default/confused24.gif)
i use a floorjack with a wooden plate. drop the tranny onto the jack and roll it out the back ...
much easier! (IMG:style_emoticons/default/shades.gif)
of course, you need to put something under the engine first to support it. a jackstand will do just fine.
(IMG:style_emoticons/default/smash.gif) Andy
jimkelly
post Jun 30 2008, 08:51 PM
Delaware USA
the engine does not need to be HIGH - but i like to have a few tokes before i get started (IMG:style_emoticons/default/smoke.gif)
good luck - safety first.
oh yeah - don't forget that damn ground strap attached to the top rear of the transaxle.
jim
type47
post Jul 1 2008, 07:08 AM
Viermeister
QUOTE(SirAndy @ Jun 30 2008, 06:15 PM) *
i gave a bad instruction that could lead to injury. and then again, i've never removed just the transmission but i've read here that someone removed the trans only by laying under it and taking it out. by far, the better method is as andy described.
Dave_Darling
post Jul 1 2008, 10:22 AM
914 Idiot
I used:
Two jack stands at the rear "donuts", adjusted as tall as they will go. One jack stand under the engine, adjusted as needed to support it. One floor jack for jacking up the car. The same jack is used to lift the trans into place when re-assembling. I just pulled the trans off of the engine by hand.
--DD
TheCabinetmaker
post Jul 1 2008, 10:26 AM
I drive my car everyday
(IMG:style_emoticons/default/agree.gif) with Dave. Thats how I do it too.
ericread
post Jul 1 2008, 03:24 PM
The Viper Blue 914
QUOTE(jimkelly @ Jun 30 2008, 07:51 PM) *
jim
(IMG:style_emoticons/default/av-943.gif)
zymurgist
post Jul 1 2008, 04:02 PM
"Ace" Mechanic
QUOTE(jimkelly @ Jun 30 2008, 10:51 PM) *
orthobiz
post Jul 1 2008, 06:15 PM
And remove the air cleaner so it doesn't hit the back of the engine compartment.
Paul
- Lo-Fi Version Time is now: 16th March 2026 - 02:35 AM
