The doctor is in today, I am here if any needs a quick tech answer |
dr914@autoatlanta.com |
Jul 4 2008, 12:11 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
770 427 2844 ext 16
Jake Raby |
Jul 4 2008, 07:38 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
George is HARD CORE!!
I would be at the shop today too, but instead I am preparing to shoot two whole weeks of instructional video in the basement.. |
PanelBilly |
Jul 4 2008, 07:54 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Lets see if your still in.... My question is..... I have my steel flairs installed now (and they're from you). I've left the edge that turns in toward the tire the same size as I received it. Its about 1/2" or so. Jon of Everett Wa has suggested I trom them off at the top to allow for the tires. Today I studied a completed car and they had actually rolled the top of the flairs inside all the way. The guy was running 9" in the back and 7" in the front. I not sure yet, but I was planning on running 8" & 7".
Do I need to trim or roll. I already have the body ready for paint> I'm working on the 600 grit at this point and am afraid of screwing up my work. But it would be so much smarter to do it now than after painting. What's your opinion? |
r_towle |
Jul 4 2008, 08:01 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Just spent the day enjoying my wonderful family...we went to the traditional parade that all the kids look forward to, even though the oldest is 21..its still in his blood to join the family.
Watched the Redsox beat the yankees again... Saw my brother and his daughter, they are coming tommorow for a bbq. so, my tech question. How do you get bbq sauce out of a pair of khakis shorts??? Rich |
PanelBilly |
Jul 4 2008, 08:04 PM
I should have check the profile for DR and I would have seen that he was off line.....
Oh and Rich, Buy new shorts and save the stained ones for working on the car when its really hot |
r_towle |
Jul 4 2008, 08:11 PM
Billy,
I have not put flares on, but I will give you this advice. Using the flared rocker panel, you line up the flares. The flares that I have seen are all a bit different, so I dont think there is a "correct" way of doing it. Its always custom and always a bit different. the key is to get the front valance to flow into the flare, then into the rocker, then into the rear valance. You can cut/add/weld onto the front and rear valances to make them flared, and the rockers are available in fiberglass. As far as the rolled edge of the fender, I would suggest you google the 914-gt to see some of the vintage pictures, or even look at the most recent parade pictures thread that includes Dr 914..George Hussey's 916 (factory applied flares) to get an idea of what the vintage flares looked like. Rich Rich |
PanelBilly |
Jul 4 2008, 08:18 PM
My concern is the lip that may rub the tire at the top of the flair. |
r_towle |
Jul 4 2008, 08:24 PM
really will depend upon your choice of rubber/wheels and spacing.
If you have the wheels, mount them up. If you have any intention of putting wheels that will fill it up...roll it now. Its alot easier to fix now then after the paint. Cover the outer fender with two or three layers of masking tape. Use a hardwood dolly and a wooden hammer with a big face. The wood will condiserably reduce the stretching of the metal and with a big hammer face and a big dolly you will also reduce the pinpoint damage of a smaller hammer. It will take longer, but if done right, no body work, or very little after your done. The tape will also cushion the blow... Just trying to keep you from having to sand all over again...but you may need to flat sand it with a long board/guide coat to be sure its straight. The other option...take a die grinder and cut the lip off so its really small...1/8 inch... Rich |
SirAndy |
Jul 4 2008, 08:27 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My concern is the lip that may rub the tire at the top of the flair. roll it ... you should be able to do so without messing up your prep work ... (IMG:style_emoticons/default/bye1.gif) Andy |
PanelBilly |
Jul 4 2008, 08:32 PM
I don't have the wheels yet so I guess it's better to allow for the most clearance. I'm thinking that I'd rather cut the lip off than roll the metal and mess up all my work.
ConeDodger |
Apex killer! Group: Members Posts: 23,593 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Heeltoe914 |
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
I always get the rims and spacers on and all lined up as I am installing fenders. The 914 is know to have a big differences from the left to the right. If you do it this way you are sure to make the gaps equal. but make sure you add the weight of the trans and the Eng, so the car sits as it would on the ground. Also try and set the camber as that affects the rear a lot in cornering.
If your not able to go at it this way get a friends car up in the air and grab a measuring tape and get it as close as you can with the rims you plan on using. And finally keep in mind you can only look at one side of the car at a time so 100% equal is not really needed. |
PanelBilly |
Jul 4 2008, 08:36 PM
My concern is the lip that may rub the tire at the top of the flair. roll it ... you should be able to do so without messing up your prep work ... (IMG:style_emoticons/default/bye1.gif) Andy I've got a friend who knows how to do body work. Last week he finished up a 59 Lister that's up for sale $750,000!!! I'll get him to come over and give me a hand. Rolling over is going to give me a stronger edge. Hell I didn't want to paint the car yet anyways. |
Bleyseng |
Jul 4 2008, 09:58 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
you have until Thursday nite to get her done in time for WCR08....
come on down! |
ericread |
Jul 5 2008, 12:00 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
I spent the entire day at Laguna Beach. Just got back. Happy belated 4th of July Dr.!
Lo-Fi Version | Time is now: 20th May 2024 - 04:42 AM |
