Rear height |
Rear height |
Bartlett 914 |
Jul 4 2008, 04:14 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I felt my car was riding too high in the front. After measuring the front height, I realized that the problem is the rear is too low. Is this simply a spring issue? What should I do to bring the rear higher?
Also when I worked on the front height I hear a knock when I bounce up and down the front. This only happens on the passenger side. I hear the noise as the car comes up. I suspected the torsion spring may have been too loose. If I tighten it the front becomes too high. I didn't go so far to see if the sound disappears. FWISW I have Bilstein gas shocks in the front. |
Jul 4 2008, 06:19 PM
What springs and shocks do you have in the rear?
That will allow us to help you with the rear ride height. Front clunk could be the upper strut nut is loose. Could be the anti sway bar is loose Could be ball joint Could be tie rod Could be bearings. Start with the first, its the most likely. Rich |
Jul 4 2008, 07:48 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Also when I worked on the front height I hear a knock when I bounce up and down the front. This only happens on the passenger side. I hear the noise as the car comes up. I suspected the torsion spring may have been too loose. i doubt it ... something is lose, but i don't think it's the torsion bar ... (IMG:style_emoticons/default/shades.gif) Andy |
Bartlett 914 |
Jul 4 2008, 07:59 PM
Thanks guys
I did change the rear springs a long time ago. Can't say why or with what. i no longer have the old ones but I do have some spare parts around I can use. Rich I will check the away bar and the strut nut ( I believe it is tight but I will check again). Seems to me that the mix of gas shocks and standard could be part of the problem. Doesn't gas shocks add some lift that isn't seen with other shocks? My front is higher for sure. The rear does look too low. I read about adjusting the height of the front in the Haynes book and that seems normal but the height for the rear has no adjustment or any specified distance that should be measured. Is there one? If this is measured and adjustable...enlighten please. |
Jul 4 2008, 08:05 PM
Thanks guys I did change the rear springs a long time ago. Can't say why or with what. i no longer have the old ones but I do have some spare parts around I can use. Rich I will check the away bar and the strut nut ( I believe it is tight but I will check again). Seems to me that the mix of gas shocks and standard could be part of the problem. Doesn't gas shocks add some lift that isn't seen with other shocks? My front is higher for sure. The rear does look too low. I read about adjusting the height of the front in the Haynes book and that seems normal but the height for the rear has no adjustment or any specified distance that should be measured. Is there one? If this is measured and adjustable...enlighten please. If you have adjustable rear perches (bilsteins and konis have these) in the rear, you can adjust the rear height...if not, there is no rear adjustment. Take a pic of the car from the side. Take a pic of the rear shock from underneath. Rich |
Lo-Fi Version | Time is now: 9th May 2024 - 03:07 AM |
