I felt my car was riding too high in the front. After measuring the front height, I realized that the problem is the rear is too low. Is this simply a spring issue? What should I do to bring the rear higher?
Also when I worked on the front height I hear a knock when I bounce up and down the front. This only happens on the passenger side. I hear the noise as the car comes up. I suspected the torsion spring may have been too loose. If I tighten it the front becomes too high. I didn't go so far to see if the sound disappears. FWISW I have Bilstein gas shocks in the front.
