Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Jan 15 2009, 08:40 AM
The bearings are in and they fit! The crank is re-assembled, were ready to rock and roll baby!! (IMG:style_emoticons/default/piratenanner.gif)
I got the rod bearings in yesterday and took them out to Christoph at lunch today along with the distributor drive gear Circlip (it was hiding in the packing popcorn of the box that I had the old crank in). So, while I was there, we checked fitment of the rod bearings...perfect and then Christoph began the crank re-assembly while I stood by and observed. OK, everything says "press" this off, "press" this on...yada, yada, yada. So far none of the Germans that I have worked with have used a press. They used a puller to get the drive gear and timing gear off and then Christoph brought out a high speed heat gun, big ass adjustable wrench and soft face hammer to put the gears back on. They also had the Porsche 914 factory book out and used it as a reference to make sure they put things back together correctly. Unfortunately, they got the timing gear on the wrong side forward the first time and had to pull the gear and redo it. Christoph did offer to give me the factory book to use for motor re-assembly but between this forum, my Haynes and the other books I have I think I should be good. Besides, mein Deutsch ist nicht sehr gut und, I would spend more time translating than actually working on the car. I plan on laying everything out and setting up my workspace tomorrow but wont' be able to get to re-assembly until probably next weekend as I head to Oberamergau to go skiing and snowboarding this weekend. Will try to get a picture of everything layed out tomorrow time permitting. Its been almost a full year from the time I picked the car up in Sicily, Italy and this adventure began. Hopefully I will be able to close the first chapter by the end of February and have her on the road. Wish me luck. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 06:41 AM |
