Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Aug 14 2009, 02:33 PM
So, I took the time to replace all the O rings on the #1 and 2 cylinders today. When everyone says it is easy well, that is a matter of opinion. #3 and 4 side is bone dry, just the 1 and 2 cylinders that had oil leaking from what I could tell.
Since I wasn't sure which one, I replaced all the O rings. 4 hours later I had it started and idling up on the lift. I didn't see any oil form under the cylinder head as I did before and I let her idle for at least 10 minutes. I did see oil forming on the bottom front and rear seam of the crankcase though. So maybe I didn't seal the crankcase as well as I thought? Can I through on any type of sealant that over the seams that will keep her from leaking? The oil is still hitting the exhaust when I stop and smoking and I have an exhaust leak in the number 1 cylinder. I will put her up on the lift again later and see what I can figure out. It looks as if I'll be keeping the car, I had put it up for sale on 914freunde.de but haven't had any interest and truthfully, I don't think I can sell her as long as she has the oil leak problem. Unlike the PO, I have a hard time passing a problem off to someone else so will probably pull the ad. What I really need is a weekend where I can drop the motor and check both seals to make sure they aren't leaking. I have two new seals that I got when Christoph also ordered some gaskets for me. If anyone has some ideas on sealling the seams without cracking open the crankcase again I am all ears! |
Bleyseng |
Aug 17 2009, 01:51 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
So, I took the time to replace all the O rings on the #1 and 2 cylinders today. When everyone says it is easy well, that is a matter of opinion. #3 and 4 side is bone dry, just the 1 and 2 cylinders that had oil leaking from what I could tell. Since I wasn't sure which one, I replaced all the O rings. 4 hours later I had it started and idling up on the lift. I didn't see any oil form under the cylinder head as I did before and I let her idle for at least 10 minutes. I did see oil forming on the bottom front and rear seam of the crankcase though. So maybe I didn't seal the crankcase as well as I thought? Can I through on any type of sealant that over the seams that will keep her from leaking? The oil is still hitting the exhaust when I stop and smoking and I have an exhaust leak in the number 1 cylinder. I will put her up on the lift again later and see what I can figure out. It looks as if I'll be keeping the car, I had put it up for sale on 914freunde.de but haven't had any interest and truthfully, I don't think I can sell her as long as she has the oil leak problem. Unlike the PO, I have a hard time passing a problem off to someone else so will probably pull the ad. What I really need is a weekend where I can drop the motor and check both seals to make sure they aren't leaking. I have two new seals that I got when Christoph also ordered some gaskets for me. If anyone has some ideas on sealling the seams without cracking open the crankcase again I am all ears! rear crankcase seam leaks ususally are the rear main oil seal leaking past the flywheel sometimes the sealing surface on the flywheel is scored creating a leak. I was just in Stuttgart to see the Porsche Museum! |
Lo-Fi Version | Time is now: 19th May 2024 - 10:55 AM |
