Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Oct 19 2009, 01:56 AM
So what does one learn when they head out at 0645 and the temps are near freezing? Well, a working defroster is a must especially when there is fog and the water from the windshield washer freezes on the window!
Other than that, the car did well, there was some smoke as the little bit of oil hit the exhaust and burned off but she definitely does not like the cold when starting in the morning. Since there is no choke I have to pump the gas and try to keep her RPMs up enough to warm the engine but this is not an option at O-dark thirty when you are trying not to disturb the neighbors. Couple of questions for the group. 1. oil tampon suggestions? Anyone ever rig something to catch minor oil leaks and prevent it from spilling on the exhaust? 2. warming the motor. Any suggestions to help this process or do I just need to put in a choke? Looking for thoughts and suggestions. |
Gint |
Oct 19 2009, 08:37 AM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
1. oil tampon suggestions? Anyone ever rig something to catch minor oil leaks and prevent it from spilling on the exhaust? 2. warming the motor. Any suggestions to help this process or do I just need to put in a choke? 1. Forget it. Put a flat drip pan under the car in the garage and call it good. Until you can repair the leak that is. Couple of times a year I take mine to the car wash and blast off the underside and then bring it home and clean up by hand. This motor I have now probably won't be in the car that long anyway. 2. Never ending battle with a carb'd type IV. Twiddle the throttle a little to get it going. Then I just let it idle really low until I'm sure oil pressure is up and then bring it up to 1-1.3k and let it run for a minute. Then I take off and try to keep it under 2.5k or 3k (at the most) for the first 5 minutes of drive time. |
stephenaki |
Oct 19 2009, 11:30 PM
1. oil tampon suggestions? Anyone ever rig something to catch minor oil leaks and prevent it from spilling on the exhaust? 2. warming the motor. Any suggestions to help this process or do I just need to put in a choke? 1. Forget it. Put a flat drip pan under the car in the garage and call it good. Until you can repair the leak that is. Couple of times a year I take mine to the car wash and blast off the underside and then bring it home and clean up by hand. This motor I have now probably won't be in the car that long anyway. 2. Never ending battle with a carb'd type IV. Twiddle the throttle a little to get it going. Then I just let it idle really low until I'm sure oil pressure is up and then bring it up to 1-1.3k and let it run for a minute. Then I take off and try to keep it under 2.5k or 3k (at the most) for the first 5 minutes of drive time. I had a feeling that was going to be the answer. Still only a minor oil leak when I got home after running the autobahn, the bigger problem now is the fact that the number 2 cylinder has developed a major exhaust leak! Will have to tackle that when I get back from Garmisch. It's gonna be a coooooooooold ride down on the bike! My buddy and I push out at 0730ish, it is 0636 and my outside thermometer is showing 28 friggin degrees! This ought to be fun! (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:22 AM |
