| kenpolives |
Jan 26 2004, 07:53 PM
Member ![]() ![]() Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2456698768
Has anyone here upgraded their fuse box, this kit looks good but....... |
| Qarl |
Jan 26 2004, 07:56 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
That would be our very own James Adams.
Check our vendor listing. I have it (not installed yet), and it looks and feels as advertised. |
| seanery |
Jan 26 2004, 08:48 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I plan on installing one when it warm enough to do so.
| Korijo |
Jan 26 2004, 08:50 PM
[]D o [] o []V[] o []D ![]() ![]() ![]() Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
ditto...
| eldiosyeldiablo |
Jan 26 2004, 09:01 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 19-August 03 From: Roswell, GA Member No.: 1,047 |
Nice but to rich for my blood. I'll wait till mine gives out.
Good work though. Looks professional. (IMG:style_emoticons/default/smilie_pokal.gif) |
| echocanyons |
Jan 26 2004, 09:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,119 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
thats real slick James!
Can you give us an idea as to how tough this is to install? |
| JWest |
Jan 26 2004, 09:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,666 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
Thanks for the kudos.
The install requires two 1/4" holes to be drilled in the fuse/relay plate (the black metal panel that unbolts from the car). Then it is all plug-and-play - just swap the wires over. It would be wise to clean all the original wire terminals while you are in there, so I would give it an hour for the job. |
| seanery |
Jan 26 2004, 09:17 PM
how's the "irritation" or annoyance factor while you're under there doing that?
| JWest |
Jan 26 2004, 09:26 PM
QUOTE(seanery @ Jan 26 2004, 09:17 PM) how's the "irritation" or annoyance factor while you're under there doing that? That's pretty hard to quantify! Access is not really a problem, as it hangs down (you don't have to do it while upside-down or anything like that). The biggest issue would be keeping the wire positions straight, and if you are methodical in swapping it should not be a big deal. I included the wire colors that go to each fuse on the cover labels, so that will help out, too. |
| hargray2 |
Jan 26 2004, 10:36 PM
fuh-q ![]() ![]() Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
NICE
how many do you have to sell before the price drops? |
| hargray2 |
Jan 26 2004, 10:39 PM
QUOTE(James Adams @ Jan 26 2004, 07:15 PM) The install requires two 1/4" holes to be drilled in the fuse/relay plate (the black metal panel that unbolts from the car). Then it is all plug-and-play - just swap the wires over. It would be wise to clean all the original wire terminals while you are in there, so I would give it an hour for the job. Don't forget to disconnect your battery or you might be sad (IMG:style_emoticons/default/sad.gif) |
| Gint |
Jan 26 2004, 11:26 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,113 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Can we do a group buy!?!?!?!
Just kidding James. Thanks for knocking out another great product. When my car finally makes it back to the streets, it will be shifted courtesy of your shifter. |
| Dave_Darling |
Jan 27 2004, 01:37 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
...And it fits right in the place of the stocker?
Dang, James--another winner! --DD |
| tat2dphreak |
Jan 27 2004, 01:42 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
looks great!! I'll have to upgrade when I run out of all of these fuses... a vw place went out of business, I bought 4 complete fuse sets! (IMG:style_emoticons/default/biggrin.gif)
| mikester |
Jan 27 2004, 02:49 PM
Member ![]() ![]() Group: Members Posts: 326 Joined: 18-June 03 From: CA Member No.: 837 |
That's definitely on my list of things to buy, I was looking at it yesterday.
It's friggin awesome. |
| jridder |
Jan 27 2004, 07:26 PM
Member ![]() ![]() Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 |
Very nice. I would caution people that the quick disconnect receptacles on the wires are quite brittle. I had to remove one and when I put it back on it seemed a little loose so I tried to bend it a bit with some pliers. I was very careful to only bend it a little bit but it still cracked and I had to replace it.
| hargray2 |
Jan 28 2004, 09:22 PM
QUOTE(tat2dphreak @ Jan 27 2004, 11:42 AM) looks great!! I'll have to upgrade when I run out of all of these fuses... a vw place went out of business, I bought 4 complete fuse sets! (IMG:style_emoticons/default/biggrin.gif) They sell euro fuses at pep boys ya know. |
| tat2dphreak |
Jan 29 2004, 10:03 AM
yea, I just got a good deal on these... 2$ /set (30 fuses, various amps) I think
| zehrschnell914 |
Jan 29 2004, 12:06 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
Considering the limited market, I'm very pleased that someone was willing to put all of the work into producing one of these! I'm putting this on my list of things to do this summer (the list is getting crowded and expensive!).
| kenpolives |
Jan 29 2004, 05:24 PM
I broke out the credit card and I should have it in a few days. I'll let everyone know how the install goes. My big problem will to find the missing yellow wire that should have been attached to my right headlight fuse. I didn't know why the light wasn't going on (new car) until I pulled out the old fusebox.......
Lo-Fi Version | Time is now: 27th November 2026 - 07:27 AM |
