Attention suspension experts!, left rear trailing arm noise |
Elliot Cannon |
Jul 19 2008, 05:42 PM
During my trip to the WCR I had a VERY loud squeek from the left rear suspension. After removing the shock, break and rear sway bar I can lift the trailing arm up with NO resistance and NO noise. Is it possible that it could be noisy only with the weight of the car on it? I bought some polygraphite bushings for it. Should I use them or opt for the more expensive roller bearing bushing, or poly bronze etc.? Are the rear roller bearing bushings even available any more?
Cheers, Elliot Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:59 PM |
