2.0 rebuild part 2, switching to carbs |
nycchef |
Jul 20 2008, 04:38 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
picked up a pair of weber 40's from rmital today. missing some of the linkage and manifolds. want to rebuild. does anyone have a pic of a complete set-up so i can see what i don,t have. also where can i find a manual on how to do it (pdf would be great)
Id on carbs weber brevettato 40 idf 48 3k Attached image(s) |
904svo |
Jul 20 2008, 05:36 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Goto webercarbs.com for the carburetor parts list. They also have more
information there that you will need. |
nycchef |
Jul 20 2008, 08:00 PM
rmital |
Jul 21 2008, 01:47 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
just a helpful (IMG:style_emoticons/default/icon_bump.gif) for Richie...need info on these relics
904svo |
Jul 21 2008, 01:56 PM
Set for sale on Ebay
http://cgi.ebay.com/ebaymotors/Type-4-pors...emZ130239184178 EMPI also sells them http://www.empius.com/2008_catalog/empi2008_pg92.html |
nycchef |
Jul 21 2008, 02:24 PM
Set for sale on Ebay http://cgi.ebay.com/ebaymotors/Type-4-pors...emZ130239184178 EMPI also sells them http://www.empius.com/2008_catalog/empi2008_pg92.html thanks found em. i am going rebuild these to stock weber specs ie; 28 main venturi 115 main jet 200 airs 50 idles f11 emulsion will ths work o a 2.0 with a web cam or should i change it. i don,t notor cross just want a peppy daily driver |
Jake Raby |
Jul 21 2008, 02:28 PM
Those venturis are too small for a 2 liter engine. The stock 28mm vents are for a 1500-1600cc engine.
try 32 vents 200 airs 130 mains 55 idle F11 emulsion Thats baseline for sea level. |
nycchef |
Jul 21 2008, 02:34 PM
nycchef |
Jul 21 2008, 10:20 PM
new problems tore down the other carb and it's a real mess. rust dirt actually found sand in the bottom. also one trottle plate screw is broken off. will have to replace both plates and the shaft.read in one post that the best way to clean out the carb is to boil it. does that mean in water? would like to make sure it,s cleanable before i start ordering parts. any ideas? (IMG:style_emoticons/default/blink.gif)
Leo Imperial |
Jul 21 2008, 11:20 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Mix and match with the set I have. One is good and the other has rust along with the noturious "sand" which I am guessing comes from the fuel break down or settling over time. I am surre the two sets combined should get you close.
nycchef |
Jul 22 2008, 08:48 AM
Mix and match with the set I have. One is good and the other has rust along with the noturious "sand" which I am guessing comes from the fuel break down or settling over time. I am surre the two sets combined should get you close. thanks sunshine. think they might survive. waiting for weber to tell me if they have the throttle shaft in stock. if so , i plan to drill out the screws and replace the whole assembly. i have some parts like the mains , venturis and idle jets that are fine , you can use them on the bus. |
rhodyguy |
Jul 22 2008, 09:12 AM
good luck on this adventure. personally i'd send the out to:
Air Cooled Engineering 360 W. 6100 #A Salt Lake City UT 84107 801-747-3341 call and explain the issues with your carbs. k |
nycchef |
Jul 22 2008, 02:04 PM
good luck on this adventure. personally i'd send the out to: Air Cooled Engineering 360 W. 6100 #A Salt Lake City UT 84107 801-747-3341 call and explain the issues with your carbs. k may come to that but right know i have more time than money and i am starting to take this thing personally. looking for a shop to ultrasound clean them around here. i'll use your guys as plan b, plan c is to shoot my 914 and lease a 911. thanks (IMG:style_emoticons/default/headbang.gif) |
Dr Evil |
Jul 22 2008, 06:52 PM
How much rust does your car have? I may consider putting you out of your misery and just buying it from you so you can lease that 911 guilt free (IMG:style_emoticons/default/smile.gif)
Seriously (IMG:style_emoticons/default/happy11.gif) |
nycchef |
Jul 22 2008, 06:59 PM
How much rust does your car have? I may consider putting you out of your misery and just buying it from you so you can lease that 911 guilt free (IMG:style_emoticons/default/smile.gif) Seriously (IMG:style_emoticons/default/happy11.gif) soon it will have none. once the engine comes out will re-do the engine bay. have the longs strengthened and por 15 the bottom. next year re build the front end drop in the carbed 2.0 and it will be perfect. i've gotten a lot better at thios than the last time you saw me. unless..; well stress test tomorrow. you might get the car in my will (IMG:style_emoticons/default/smoke.gif) |
Dr Evil |
Jul 22 2008, 08:15 PM
nycchef |
Jul 23 2008, 05:58 PM
can anyone recommend a shop that can ultrasound clean my carbs? want to make sure they're as clean as new before i rebuild. as usual can't find anyone in nyc.
HeloMech |
Jul 24 2008, 10:41 AM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
Did you ever find the pics of carbs and linkage you were looking for?
I just picked these carbs up with the linkage. I pulled them from a 2.0L for my 2.0L. http://www.914world.com/bbs2/index.php?showtopic=86326 |
nycchef |
Jul 24 2008, 11:21 AM
Did you ever find the pics of carbs and linkage you were looking for? I just picked these carbs up with the linkage. I pulled them from a 2.0L for my 2.0L. http://www.914world.com/bbs2/index.php?showtopic=86326 not yet just p/u manifolds. what size carbs are those? you have 2 fuel inlet pipes where mine have 1 and a plug on the other side. also what did you guys mean you are missing a barrel? do you want to sell the linkage? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 AM |
