> My MicroSquirt Install
McMark
post Jul 20 2008, 05:00 PM
Post #101
914 Freak!
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate.
Anyway, now on the the fun stuff!
I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today.
McMark   My MicroSquirt Install   Jul 20 2008, 05:00 PM
McMark   Here is the wiring harness I had Jeff Keyzer make ...   Jul 20 2008, 05:10 PM
Gint   Giddyup! Right on Mark. Microsquirt? Never ...   Jul 20 2008, 05:33 PM
r_towle   This looks very interesting. Is the microsquirt j...   Jul 20 2008, 05:36 PM
ejm   They have an info page and forum   Jul 20 2008, 05:42 PM
ericread   How about some background information? 4-Cylinder...   Jul 20 2008, 06:00 PM
McMark   This setup will be expensive. But doing it right ...   Jul 20 2008, 06:01 PM
type47   MAP: $64 not able to figure out the MAP ...   Jul 22 2008, 07:56 AM
Rick_Eberle   not able to figure out the MAP reference. what is...   Jul 22 2008, 10:13 AM
Zundfolge   This setup will be expensive. I think when every...   Jul 23 2008, 03:04 PM
toon1   Looks good Mark .   Jul 20 2008, 06:26 PM
McMark   Cold start block off... MS does cold start enrich...   Jul 20 2008, 07:07 PM
rick 918-S   Nice work Mark! :popcorn:   Jul 20 2008, 07:29 PM
Rick_Eberle   Looks great! Where are you planning to mount i...   Jul 20 2008, 07:37 PM
SirAndy   schweet! :trophy: how about using these fo...   Jul 20 2008, 08:04 PM
Jeff Bowlsby   Yay Mark! :drooley: Yay Jeff K :worship:   Jul 20 2008, 08:11 PM
Joe Owensby   Great work. I am thinking of going to one of th...   Jul 20 2008, 08:14 PM
McMark   Brain will be in the stock location. MAP sensor ...   Jul 20 2008, 09:17 PM
mikez   Go for it....good luck. I got the bad news toda...   Jul 20 2008, 10:25 PM
jkeyzer   Nice writeup Mark! I am glad to be involved i...   Jul 20 2008, 11:21 PM
Elliot Cannon   Modern fuel injection is the way to go. My trip t...   Jul 21 2008, 01:20 AM
james2   your webers need work, my 56 oval gets 26 mpg with...   Jul 21 2008, 06:03 AM
watsonrx13   Very nice Mark. I just finished reading Excellence...   Jul 21 2008, 06:31 AM
RJMII   Glad to see someone doing this! You going to d...   Jul 21 2008, 12:11 PM
retrofit   :driving: Looking forward to taking this for a tes...   Jul 21 2008, 01:03 PM
jgara962   Looks like a cool project Mark. What are some of...   Jul 21 2008, 02:47 PM
Dr Evil   I'd love a 6cyl version :) Nice job man :thumb...   Jul 21 2008, 06:51 PM
TimT   Microsquirt cant do a 6 cyl. It only has two ignit...   Jul 21 2008, 07:33 PM
Rotary'14   Microsquirt cant do a 6 cyl. It only has two igni...   Jul 21 2008, 08:50 PM
Dr Evil   Why cant you batch fire a 6 like the 4 does?   Jul 21 2008, 09:26 PM
Brian_Boss   Stock 911 Carrera Motronic batch fires the injecto...   Jul 21 2008, 09:49 PM
Dr Evil   Stock 911 Carrera Motronic batch fires the inject...   Jul 21 2008, 09:55 PM
TimT   Batch firing injectors is fine... The ignition is ...   Jul 22 2008, 02:09 AM
McMark   The number one reason is the customer wanted FI. ...   Jul 22 2008, 11:33 AM
RJMII   Megasquirt II and Microsquirt can be configured to...   Jul 22 2008, 11:46 AM
TimT   Not so much that they are built into the system ...   Jul 22 2008, 07:01 PM
grantsfo   Not so much that they are built into the system...   Jul 23 2008, 09:16 PM
TimT   I happen to have the engine of my car out while I ...   Jul 22 2008, 07:08 PM
TimT   In this pic you can see the TPS, IAT, CAS, and if ...   Jul 22 2008, 07:09 PM
McMark   No problem. All good info. :thumbsup: I have mo...   Jul 22 2008, 11:53 PM
McMark   Here are some more pictures of the installation as...   Jul 23 2008, 12:23 PM
ClayPerrine   Really cool work. :idea: Now if you really wan...   Jul 23 2008, 01:08 PM
porsche913b_sp   Really cool work. :idea: Now if you really wa...   Jul 23 2008, 01:22 PM
McMark   DHunt did that. Said it was a royal PITA. This ...   Jul 23 2008, 08:20 PM
TimT   Mark, If I were doing this install I might do some...   Jul 24 2008, 01:22 AM
McMark   If this were a traditional MS install I would defi...   Jul 24 2008, 11:30 AM
smdubovsky   The microsquirt uses ampseal(?) connectors. We us...   Jul 24 2008, 12:12 PM
McMark   Here's the picture of the AMPSEAL connector. ...   Jul 24 2008, 07:53 PM
RJMII   Here's the picture of the AMPSEAL connector. ...   Nov 13 2008, 12:13 PM
smdubovsky   Where does that connector go? is that the one tha...   Nov 13 2008, 01:05 PM
kconway   [quote name='RJMII' post='1101721' date='Nov 13 2...   Nov 13 2008, 02:50 PM
RJMII   Looks like they can be had here with a min buy of...   Nov 13 2008, 04:41 PM
smdubovsky   Looks like they can be had here with a min buy of...   Nov 17 2008, 01:21 PM
biggy72   How did this thing turn out? Everything run alrigh...   Nov 13 2008, 12:15 AM
Gint   :bump: How did this turn out?   Nov 13 2008, 08:59 AM
rick 918-S   Just re-read the whole thing. Cool. :popcorn: :tt...   Nov 13 2008, 10:27 AM
Root_Werks   This is a good thread. Certainly an update or may...   Nov 13 2008, 11:13 AM
LarryR   Hey Mark, That is sweet! I saw a few earlier...   Nov 13 2008, 10:30 PM
CliffBraun   Re MS and going distributorless, there is apparent...   Nov 14 2008, 12:48 AM
banger   Actually you can do coil on plug quite easily with...   Nov 14 2008, 11:37 AM
CliffBraun   Actually you can do coil on plug quite easily wit...   Nov 14 2008, 03:50 PM
sean_v8_914   considering what you get and the current cost and ...   Nov 14 2008, 10:21 AM
horizontally-opposed   :popcorn: :popcorn: :popcorn: Me, myself, and ...   Nov 14 2008, 11:09 AM
McMark   Okay, here's the update... The MicroSquirt do...   Nov 14 2008, 11:32 AM
Mark Henry   I'd go with the coils Tim has in his pic's...   Nov 14 2008, 11:40 AM
type47   what is the compatibility between MS and the type ...   Nov 14 2008, 05:11 PM
Marty Yeoman   What is the compatibility between MS and the type...   Nov 14 2008, 05:25 PM
Mark Henry   What is the compatibility between MS and the typ...   Nov 14 2008, 05:35 PM
Rick_Eberle   what is the compatibility between MS and the type...   Nov 14 2008, 05:38 PM
McMark   :agree: with both of the above. Every new cam, or...   Nov 15 2008, 11:17 PM
hulken   :agree: with both of the above. Every new cam, o...   Mar 14 2009, 05:50 AM
ConeDodger   Nice Mark! The fan comes apart right? What if ...   Nov 16 2008, 12:12 PM
McMark   It would definitely work, it would just be lots mo...   Nov 17 2008, 11:24 AM
toon1   Nice trigger wheel Mark. I mounted the VR sens...   Nov 17 2008, 12:59 PM
3d914   Jim & Marty, I had the Web #73 cam with my 2....   Nov 17 2008, 01:33 PM
McMark   FINALLY made some more progress on this install. ...   Jan 5 2009, 09:43 PM
Bartlett 914   [b][i]FINALLY made some more progress on this ins...   Jan 6 2009, 04:58 PM
jhadler   This looks like you are moving the fan out by the ...   Jan 6 2009, 05:19 PM
McMark   Videos!<br> <object type="appli...   Jan 5 2009, 10:14 PM
alex914   That's great! Videos!<br>   Jan 6 2009, 04:23 PM
toon1   Slick!!   Jan 6 2009, 09:35 AM
Dr Evil   Can you use the micro squirt without the ignition ...   Jan 6 2009, 04:35 PM
toon1   Can you use the micro squirt without the ignition...   Jan 7 2009, 09:25 AM
jhadler   Okay! That's super slick! Giving me a...   Jan 6 2009, 04:47 PM
McMark   Yup, the timing gear is the exactly the same thick...   Jan 6 2009, 07:21 PM
Bartlett 914   Yup, the timing gear is the exactly the same thic...   Jan 7 2009, 09:20 AM
McMark   MicroSquirt can do fuel only, but you'll still...   Jan 7 2009, 05:22 PM
smdubovsky   MicroSquirt can do fuel only, but you'll stil...   Jan 7 2009, 05:35 PM
Dr Evil   I'll do the Mega Squirt, then. The guy wants i...   Jan 7 2009, 07:04 PM
Krieger914   Nice work Mark! Keep us posted.   Jan 7 2009, 07:27 PM
McMark   I originally tried to run the MicroSquirt fuel onl...   Jan 8 2009, 02:53 PM
Brian_Boss   I'm sure Mark considerd this but why couldn...   Jan 8 2009, 11:01 PM
toon1   I'm sure Mark considerd this but why couldn...   Jan 9 2009, 09:08 AM
smdubovsky   D-jet points trigger the coil directly? (excuse my...   Jan 9 2009, 10:52 AM
Dave_Darling   The D-jet points only hook up to the ECU, not to t...   Jan 9 2009, 10:54 PM
McMark   Jeff Keyzer and I installed the MicroSquirt on a m...   Jan 22 2009, 06:19 PM
jkeyzer   Mark's VR sensor solution is top notch. Great...   Jan 22 2009, 07:28 PM
McMark   Yeah, I was really surprised by how clearly the MS...   Jan 22 2009, 08:40 PM
McMark   UPDATE: JeffK (mightyohm) came by again today and ...   Jul 2 2009, 08:10 PM
chocolate.curry   I didn't see this mentioned earlier in this th...   Jul 3 2009, 06:06 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:58 AM
