| Qarl |
Jan 28 2004, 06:15 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have a set of fiberglass front and rear bumpers for the conversion car. Purchased from PMS. (Made by someone else, I'm sure).
Anyways, I need brackets that I can glass in so I can use the factory mounting holes. Anyone know of a source? it's not a simple 90 degree bend... it involves some weird angles. Or can anyone post some pictures of another solution? Thanks! |
| Eric_Shea |
Jan 28 2004, 06:21 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Mine are U-shaped mount similar in design to what's on the back of the turn signal bucket only vertical. Long enough to cover both bolt holes on the body and set (fiberglassed) in at an angle. Mine were from Rennspooge and the passengers side was set in backward...grrrrrrrrr (IMG:style_emoticons/default/ar15.gif)
Like this only bigger (IMG:style_emoticons/default/wink.gif) _ |_ Hope that helps... E. |
| echocanyons |
Jan 28 2004, 06:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
getty has some in there catalog 50$ a pair
| brant |
Jan 28 2004, 06:51 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,156 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I can't remember where...
but 10years ago, we bought ours seperate from the bumper. they don't have to be glassed in if you run the bolt through the bumper and through the mount as a spacer.... I used a flat head carriage type bolt which doesn't even look bad. I've got 2 new bumpers for the new car (also with no brackets) and I'm not going to buy them this time but rather just build something from sheet aluminum to be the spacer. brant |
| Qarl |
Jan 28 2004, 07:13 PM
Getty Design isn't making them anymore... nor is GT racing...
| Joe Bob |
Jan 28 2004, 07:18 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Aluminum channel stock....sawzall and a lot of fitment and swearing....
| Howard |
Jan 28 2004, 07:53 PM
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None
A job I haven't done since this morning! here's the link to the actual part: http://gettydesign.com/Catalog/2003%20Onli...alog%20v1.0.pdf
But the bumpers are so light you can just use 1/16 x 1 1/2 aluminum bar stock. Any hardware store will have, and you can cut it with tin snips and bend it with pliers. The bumpers are fragile so when you get hit the aluminum will 'give' a bit and bumper has a better chance of surviving. I glassed 'em to bumpers. |
| URY914 |
Jan 28 2004, 08:50 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Damn, I just cut mine out of my front bumper. It was steel flat bar 1/8" x 1" with two tapped holes for the mounting bolts and glassed into the bumper. See if AIR in LA will send you a set.
Paul |
| URY914 |
Jan 28 2004, 09:03 PM
If you can't find a set. I would try make a "buck" out of stroform to get the shape right. It's easy enough to cut and shape and test fit it until it works. Once you get it right, make a aluminum or steel piece.
Paul |
| campbellcj |
Jan 28 2004, 10:34 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,703 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
I have a front bumper from GT that has built-in f/g "tabs" in approximately the location where the stock bracket and dogbones sit.
I riveted in some "rivnuts" and use a stock-ish bolt on setup. Piece of cake. I may actually glass it into the spoiler and convert the whole front to dzus fasteners shortly though. On the rear, GT supplied the alum brackets which are kind of "L" shaped. They would be easy to dupe with a cheap sheet metal brake and jigsaw or cutoff wheel. |
| maf914 |
Jan 29 2004, 07:55 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
QUOTE(URY914 @ Jan 28 2004, 07:03 PM) If you can't find a set. I would try make a "buck" out of stroform to get the shape right. It's easy enough to cut and shape and test fit it until it works. Once you get it right, make a aluminum or steel piece. Paul That sounds like a good idea. Perhaps you could form the foam to the right shape, glass it, then glass it to the bumper, and use it for the mount. Figuring out how to locate the bolts might be a trick though. Mike |
| maf914 |
Jan 29 2004, 09:53 AM
Karl,
Hmm... Didn't you start out with metal bumpers? If so, do you still have them and want to get rid of them? Mike |
| Qarl |
Jan 29 2004, 11:32 AM
no metal bumpers. I started out with big ugly rubber ones (1975)
| maf914 |
Jan 29 2004, 02:35 PM
Yeah, I remember the 75, but I thought on your site you had some photos of a test fit with steel bumpers. Might have been brain fade.
Mike |
Lo-Fi Version | Time is now: 9th March 2026 - 10:37 PM |
