Tail Light Wiring |
Tail Light Wiring |
STL914 |
Jul 24 2008, 12:02 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Can someone post a drawing or sketch showing how the tail lights in a '72 should be hooked up; what color wires go to which spades?
Also, which bulbs should flash when the directional are activated? The light hand acts differently than the right hand assembly. |
7275914911 |
Jul 24 2008, 01:07 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Sorry I don't have the direct link.....but search for Tail Light Wiring in the Title Only. There are several good threads with pics and sketches..
Good Luck JKP |
dbgriffith75 |
Jul 24 2008, 01:38 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
I don't know if there's any difference in wire color, but here's how it's wired up on my '75. I did my best to colorize it for you.
G e o r g e |
Jul 24 2008, 01:40 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
1c
Attached thumbnail(s) |
G e o r g e |
Jul 24 2008, 01:41 PM
2d
dbgriffith75 |
Jul 24 2008, 01:45 PM
Oh sure, I go to the work of making a sketch for the guy, and you just swoop in here with your fancy digital camera and your put together car and your original wiring harness and show him how it should be!
Well, that's the last time I ever make an effort for somebody else! ... (IMG:style_emoticons/default/biggrin.gif) |
Todd Enlund |
Jul 24 2008, 01:46 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
I have a melted wire under the dash... I discovered that the left high beam headlight is (well, in my case, was) grounded through the high beam indicator in the tach! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:27 AM |
