OT Car Audio, Wiring and amps |
Jul 29 2008, 09:18 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
For my sons car he has built a pretty big sub woofer into a center console. He would like to run TWO amps to power the sub woofer. He has these two amps . He got both at different places years ago and would now like to use both of them to power just the sub. So, how can this be done? Is it possible to run the sub with two amps at the same time? Please explain (more than "just bridge them") Thanx Rich |
Demick |
Jul 29 2008, 11:00 PM
I don't think so, unless he has a dual voice coil sub (and even then, it's probably not a good idea).
Demick |
McMark |
Jul 29 2008, 11:49 PM
Newer amps have a special terminal for syncing multiple amps so he waveforms match. This sounds like a recipe for blown components.
RJMII |
Jul 30 2008, 06:33 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I agree with Mark, sounds like a recipe for blown components.
It takes a special setup of amps and sub to power one sub with two of them. He'd be better off getting one amp that has enough power output for the car. In DVC setup: each coil has to have an identical signal to the other. same power, same wattage, same polarity. If one coil has a different amount of power, or the polarity is flipped, it will cause a variation in the electromagnetic field and will either have terrible distortion or tear itself apart. In SVC setup: The amps would have to be rated to handle being run along with another amp. The increase in the amount of power going through the coil causes that the amp sees less resistance, extra help, yadda yadda and it shorts the amp out. |
Lo-Fi Version | Time is now: 21st May 2024 - 08:24 PM |
