Regulator panel wiring, T4 connector |
zonedoubt |
Aug 2 2008, 03:08 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The T4 connector on the regulator/relay panel is not marked to indicate which connector is which. Can someone confirm if I've numbered these correctly. I think they are because the yellow wire is supposed to go to T4-2 which is one of the two rear connections.
According to the electrical schematic T4-2 and T4-4 are tied together and go to ignition switch. On my car, there is a black wire (see photo) which leads to a switch under the dash which is connected to the fuel pump. The engine was carb'ed which I have removed and reinstalled the fuel injection. According the schematic T4-1 and T4-3 go a "power supply relay" which I assume is how the fuel pump is currently operated. I'm going to set the fuel pump circuit up how it's supposed to be. Any advice? |
Lo-Fi Version | Time is now: 15th May 2024 - 01:06 PM |
