Made some progress - getting closer! |
Phoenix-MN |
Aug 2 2008, 04:43 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I finished all the engine wiring and plumbing and thought I should check the started/flywheel/ring-gear engagement before I put it in the car. Filled it up with BP breakin oil ,hooked up the battery and pressed the remote started switch and it came to life (IMG:style_emoticons/default/piratenanner.gif) No funny sounds or grinding. I then pulled the starter off to inspect the gear engagement and everything looks cool. I put the starter back in and hooked up an oil pressure gauge turned it over some more and got about 2 bar pressure on the gauge. (IMG:style_emoticons/default/smilie_pokal.gif) Next step.... Get it in the car.
Paul |
biosurfer1 |
Aug 2 2008, 04:53 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Lo-Fi Version | Time is now: 21st May 2024 - 04:18 AM |
