I finished all the engine wiring and plumbing and thought I should check the started/flywheel/ring-gear engagement before I put it in the car. Filled it up with BP breakin oil ,hooked up the battery and pressed the remote started switch and it came to life No funny sounds or grinding. I then pulled the starter off to inspect the gear engagement and everything looks cool. I put the starter back in and hooked up an oil pressure gauge turned it over some more and got about 2 bar pressure on the gauge. Next step.... Get it in the car.
Paul
