Bad alternator?, Or something else? |
Brew |
Aug 6 2008, 12:08 PM
That's Captain Moron to you! Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 |
Leaving work yesterday, heading to the golf course, the charging system idiot light came on , and the volt gage went to zero ....but until I got to a stoplight, everything else was working. Then, everything stopped working (tach, temp gage)....until I got the car moving again. (IMG:style_emoticons/default/WTF.gif) The charging system was still showing no signs of life, but the temp gage and tach looked to be working normally. I couldn't get the rpm up high enough to make anything work while sitting still, only when the car was moving! I continued on to the golf course, played a round, started the car back up (no problem), and drove it some 5 miles back home. I don't get it.... (IMG:style_emoticons/default/confused24.gif)
Is it the alt., or something else? BTW, if anyone has the link to the best method of alternator replacement, please post it! Thanks! |
Bartlett 914 |
Aug 6 2008, 12:32 PM
Leaving work yesterday, heading to the golf course, the charging system idiot light came on , and the volt gage went to zero ....but until I got to a stoplight, everything else was working. Then, everything stopped working (tach, temp gage)....until I got the car moving again. (IMG:style_emoticons/default/WTF.gif) The charging system was still showing no signs of life, but the temp gage and tach looked to be working normally. I couldn't get the rpm up high enough to make anything work while sitting still, only when the car was moving! I continued on to the golf course, played a round, started the car back up (no problem), and drove it some 5 miles back home. I don't get it.... (IMG:style_emoticons/default/confused24.gif) Is it the alt., or something else? BTW, if anyone has the link to the best method of alternator replacement, please post it! Thanks! Crazy problem. I would start with the usual suspects. Check battery connections and your grounds. |
Cap'n Krusty |
Aug 6 2008, 01:03 PM
If you're gonna "start with the usual suspects", look at the fuses FIRST. Then make sure the red light comes on with the key, then progress to the other things. The Cap'n
TINCAN914 |
Aug 6 2008, 01:19 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I would start with inviting a friend next time you go play golf ya jagoff. (IMG:style_emoticons/default/poke.gif)
Bartlett 914 |
Aug 6 2008, 01:21 PM
If you're gonna "start with the usual suspects", look at the fuses FIRST. Then make sure the red light comes on with the key, then progress to the other things. The Cap'n O.K. fuses first but he did state that the red light was on but later things were normal. If it is a fuse then it would be a bad connection at the fuse. |
ericread |
Aug 6 2008, 01:23 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) with both of the above. Check all the wiring.
If you do need to change out the alternator, use the instructions in the Pelican site. I have it down to a full replacement, by myself, in 60 minutes. A result of waaaaay too much incorrect troubleshooting last summer (but it turned out it actually was the alternator, so I got lots of practice). Oh, take a look at the alternator belt too. Eric Read |
Brew |
Oct 1 2008, 08:23 AM
So after almost 2 months of pondering the problem (and plain old slacking), I got the alt replaced. No difference. Changed the voltage regulator. No difference. The charging system is working, but there's no indication of it working from inside the car. (IMG:style_emoticons/default/mad.gif)
Fuses all look good, so I'm guessing it's probably a bad ground....somewhere? Also, not sure if it's related, but I dont have turn signals or brake lights now. Is there a specific ground that could be attributed to both problems? |
SGB |
Oct 1 2008, 06:03 PM
Sounds similar to a problem I've started having in the last 2 days. Shortest story: Car gets completely to temp, starter no clicky at all. Wait 2 hours and "RRReerrrr" starts right up. Today: No clicky at first (cold) try. This is new. Put on charger, 1 minute later it goes "bing" and the car stats right up BUT- as I go to work, using flasher and suddenly the volt needle starts a-jumpin like crazy.
And now the car acts like nothing has changed; no problems- YET. I think it is the BATTERY. A freind with a VW shop has had similar experiences (no flasher effect though). So thats what I guess I''l buy. |
Oct 1 2008, 06:37 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
There are many grounds on a german car...
There is one one the drivers inside fender for the fuse box.. Its not easy to see, but its up in there. I tend to hit the fuse box with my big ass feet ALOT... I often look down (in the dark) and find fuses laying on the floor. Check all the grounds, check the light switch for possibly shorting out also. Rich |
BMartin914 |
Oct 1 2008, 06:46 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Could be your regulator John.
Before you spend more money, find out where you have power and where you don't. The charging system is pretty straightforward. Like the cap'n says, the gen light should flash when you start the car. And again when you shut it off. That light "starts" the alternator more or less. |
TROJANMAN |
Oct 1 2008, 11:01 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
John,
Try looking in the classifieds. If you find another car you like, it might solve all of your problems. Just trying to help (IMG:style_emoticons/default/wink.gif) |
dbgriffith75 |
Oct 2 2008, 10:19 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
Check and/or clean the connections on the plugs of the cord running from the alt. to the relay board while you're at it. Sometimes a dirty connection can be a real nasty thing...
Lo-Fi Version | Time is now: 20th May 2024 - 09:39 PM |
