Carbon Canister, Replacment carbon |
Bartlett 914 |
Aug 11 2008, 06:10 PM
I may have access to some bulk carbon that is used in filters. It is in power form not pellets. I was wondering if maybe this could be put in a bag like an old sock or something and inserted in the canister to replace the old carbon. What do you guys think?
Aug 11 2008, 07:05 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
carbon You'll need activated carbon/charcoal ... Otherwise it'll be useless ... http://en.wikipedia.org/wiki/Activated_carbon (IMG:style_emoticons/default/shades.gif) Andy |
JeffBowlsby |
Aug 11 2008, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,521 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I would think you would need pelletized not powder, to allow air/fuel vapor to penetrate thru the charcoal filter medium...
ArtechnikA |
Aug 11 2008, 07:33 PM
I may have access to some bulk carbon that is used in filters. It is in power form not pellets. I was wondering if maybe this could be put in a bag like an old sock or something and inserted in the canister to replace the old carbon. What do you guys think? Since you ask, I think you have a 'SWAP' - a Solution Without A Problem... The carbon just provides a relatively inert place for gasoline vapor to collect until it can be re-aspirated into the intake. A big inert sponge. So - what problem are you trying to solve? |
Pat Garvey |
Aug 11 2008, 07:52 PM
I may have access to some bulk carbon that is used in filters. It is in power form not pellets. I was wondering if maybe this could be put in a bag like an old sock or something and inserted in the canister to replace the old carbon. What do you guys think? Since you ask, I think you have a 'SWAP' - a Solution Without A Problem... The carbon just provides a relatively inert place for gasoline vapor to condense so it can drip back into the tank. So - what problem are you trying to solve? My understanding is that the carbon, in the filter, has no short life. It collects the vapors(hydrocarbons), recirculates them, re-uses them to be burned in the system, and is somewhat self cleaning. As far as I can see, they should never need replacing. Other opinions? Pat |
Aug 12 2008, 12:27 AM
Other opinions? Yes. (IMG:style_emoticons/default/biggrin.gif) The factory called for regular replacement. Looks like they thought it was a wear item ... The pellets will eventually turn to dust. I don't think any of the 30+ year old canisters has anything left in them ... (IMG:style_emoticons/default/shades.gif) Andy |
Chris Pincetich |
Aug 12 2008, 12:34 AM
Any good aquarium store has activated carbon in little rocks all bagged in plastic mesh for use in filtering systems. I ditched mine recently since I mostly race locally and never really have more than 1/2 tank of gas.
Bartlett 914 |
Aug 12 2008, 08:04 AM
Thanks for the input. I will get a chance to see the stuff tomorrow. It is in a plant that is being shut down. This material will be tossed. I would have to pay shipping to keep it. I agree that pellets would be better than powder. It was the idea of placing it in bags that may make it usable in the canister.
rick 918-S |
Aug 12 2008, 08:17 AM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I agree the pellet type would be better. Power would likely not allow a free exchange of vapor to pass.
ericread |
Aug 12 2008, 08:29 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Other opinions? Yes. (IMG:style_emoticons/default/biggrin.gif) The factory called for regular replacement. Looks like they thought it was a wear item ... The pellets will eventually turn to dust. I don't think any of the 30+ year old canisters has anything left in them ... (IMG:style_emoticons/default/shades.gif) Andy As I was changing out my steering rack a couple of weeks ago, I removed the canister and took a look inside. All the pellets look good as new! The seal on one side of the canister had come undone a bit, and I was getting gas fumes in the front trunk. I popped the side back on, making sure it sealed all the way around, and presto-chango, no more gas fumes (YAY!) Eric Read |
JeffBowlsby |
Aug 12 2008, 10:30 AM
Attached thumbnail(s) |
ericread |
Aug 12 2008, 01:20 PM
Note that it doesn't instruct you to replace, just viaually inspect. You need to make sure it wasn't stolen???
Eric |
JeffBowlsby |
Aug 12 2008, 02:09 PM
WHAT PART OF "REPLACE EVERY 50OOO MILES" DO YOU NOT UNDERSTAND SON?
thats the first time I have shouted online...dont take me too seriously...(IMG:style_emoticons/default/biggrin.gif) |
Aug 12 2008, 03:26 PM
Note that it doesn't instruct you to replace, just viaually inspect. You need to make sure it wasn't stolen??? Huh? (IMG:style_emoticons/default/confused24.gif) Maybe you should have another look at the chart ... - Maintenance schedule, every 10,000 miles, 12. Activated Charcoal Filter: Visually check - Replace every 50,000 miles visually check every 10,000 miles, replace every 50,000 miles ... (IMG:style_emoticons/default/shades.gif) Andy |
ArtechnikA |
Aug 12 2008, 03:41 PM
Lo-Fi Version | Time is now: 28th May 2024 - 03:13 PM |
