BIG Worries HELP dry valves!, oil pump |
Mike Gilbert |
Aug 12 2008, 03:07 PM
Pcar fan Group: Members Posts: 32 Joined: 4-August 08 From: Collierville, Tn. Member No.: 9,389 Region Association: South East States |
ok i bought this car last week and it has not been ran in years.but i did get it running and have ran it several time since.i go to take the vavle cover off to adjust the valves and no oil ran out and everything under the valve cover is dry. what the heck is wrong with this picture?is my oil pump not working?am i just clueless to how this engine works?please help. oh its a 72 with a 1.7, mike(yes it has oil, 3qt.s)
dbgriffith75 |
Aug 12 2008, 03:29 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
If the car hasn't been run in years, it's possible that there's gunk in the valve stems and/or pushrods that's preventing oil from being pushed through. It's also possible that the oil sump is plugged.
And this is just my personal advice, but even though you've got the car running, I reccomend a rebuild. It's hard telling what might be floating around in that engine, even if you've changed the oil. |
Aug 12 2008, 03:31 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
4 quarts would be better...
Rich |
Mike Gilbert |
Aug 12 2008, 10:32 PM
i found out now that i have a blown head gasket so the motors coming out for that.the other cylinders have great compression.not much if any smoke on start up.has some blowby.
Lo-Fi Version | Time is now: 29th May 2024 - 06:38 PM |
