> clutch questions
TheCabinetmaker
post Jan 31 2004, 08:36 PM
I drive my car everyday
While pulling the motor from my friends car for a top end renewal, and removing the clutch cable I found a 13mm sockett under the adjustment nut. Someone
had put it there so they could adjust the clutch. I took it off and reattached the cable, but without it there was not enough adjustment. My first thought was a very stretched or wrong cable, but its the same length as a new one I have. Pulled clutch today. There is about an eighth inch of clutch left to the rivets. How thick are the faces on a new clutch?
Would a worn out clutch cause the extreme adjustment problem?
Thanks,
- Lo-Fi Version Time is now: 9th July 2025 - 08:17 AM
