Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Joe only lives about ten minutes from my shop...
I will drop by whenever you say and we can go from there. Rich |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
Uhhhhhh Ohhhhhhhhhh My passenger door is sagging and I need an inexpensive way to fix it. My goal is not to have a show car but a decent driver ( without a sagging frame). I do not think it is too bad yet but the passenger door is deffinently off. I placed a jack under the front and when I raised the car the door aligned prety good. I have attached a couple of pics if it helps. It looks like the P.O did some work because the the outter portion of the long looks fairly good. Also I removed the carpet to see if that revealed anything and it looks pretty good. I can not see anything from inside the car but under there is some rust. It does not look as bad as some that I have seen but I am not an expert by any means. Any suggestions on what I could do to get by. Just be greatful that its not saggen like Mimi`s mam`s on the hot chick`s thread.At least you can fix yours |
JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
Rich is the man!!! He will be stoping by sometime on Friday to take a look. I will keep you all posted. Thanks again to everyone.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,320 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Rich is the man!!! He will be stoping by sometime on Friday to take a look. I will keep you all posted. Thanks again to everyone. Feed and beer him well! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beer.gif) Looking forward to update... |
JOE M |
I offered him beer ,wine, and even a rib eye steak for lunch but he does not do lunch-lol. Worst case is I drink his (IMG:style_emoticons/default/beer3.gif)
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
No question - you are doing this the right way. Rich knows what to look for and will be able to tell you how to fix whatever it ends up being.
Here's hoping its just wonky door alignment. (IMG:style_emoticons/default/smile.gif) Zach |
JOE M |
No question - you are doing this the right way. Rich knows what to look for and will be able to tell you how to fix whatever it ends up being. Here's hoping its just wonky door alignment. (IMG:style_emoticons/default/smile.gif) Zach Thanks for you optimistic outlook Zach. Here are a few more pics. inside of the car,under the rear wheel well and along the bottom. Hope these reveal something. ![]() ![]() ![]() |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
We also need to see the area directly above the area in your last pic. That's the bottom of the long, it would be nice to see the area below and in front of where the battery is/was, the RF lower corner of the engine compartment.
bottom of long has been patched and welded
Inner long has been welded to floor hello hole bottom has been welded... Overall I think you are fine, just a bit of tweeking and ALOT of elbow grease to clean the current rust and undercoat it... Rich |
VaccaRabite |
bottom of long has been patched and welded Inner long has been welded to floor hello hole bottom has been welded... Overall I think you are fine, just a bit of tweeking and ALOT of elbow grease to clean the current rust and undercoat it... Rich So whats with the door gap? Did the tub twist when it was welded, or is the door just out of alignment? Zach |
when I get there I will take a look.
I think we can get alot of that out with a decent adjustment. Rich |
JOE M |
From the response I think it sounds prommising. Het Rich do you own the garage on 113 in tyngsboro just before the fire station?
nope, I live in Dunstable and my shop cant really be seen from the road unless you really slow down..
R |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
nope, I live in Dunstable and my shop cant really be seen from the road unless you really slow down.. R Kinda of like the batcave? (IMG:style_emoticons/default/laugh.gif) OT: Hey Rich, I got rid of most of the exhaust leak by removing the bolts between the exhaust and HEs and then re-tightening the cooper nuts (as you suggested at the CFR party). I'm guessing the remaining leak is probably the ends of the HEs not being flush with each other. I'll fix that when I put the 2.0 in this winter. |
Joe's car is fine.
Looks like alot of welding was done on the passenger side...fairly decent job. The jack post was never put on...but a new outer long was... Looks like the long may have shrunk a bit due to welding and the door was never adjusted properly... I showed him how to adjust it and went through a bit of talk on his carbs... Made a new 914 friend and along with his supportive wife, he will get it running like a charm..hes almost there... Rich |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)(IMG:style_emoticons/default/smilie_pokal.gif)
Horaay! Happy endings are great! Thanks for reporting back Rich. |
VaccaRabite |
Awesome.
zach |
sww914 |
THAT'S what this place is all about!
Cool. |
dlestep |
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States ![]() |
![]() cut holes and put yer feet through 'em |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
B Sure.
Please. Take it deeper and be sure. Crunchy Zone is danger zone. B-SHURE |
Lo-Fi Version | Time is now: 14th July 2025 - 04:50 AM |
