SSI Heat Exchanger Modification, Modify 1.7 HE to 2.0 |
t collins |
Aug 21 2008, 06:01 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Just curious if anyone here has ever converted a set of Stainless Steel Heat Exchangers over from 1.7 to 2.0 ? (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
Cap'n Krusty |
Aug 21 2008, 06:03 PM
Be mo' beta to just buy the muffler and the hanger ........................ The Cap'n
t collins |
Aug 21 2008, 06:26 PM
Rusty |
Aug 21 2008, 06:35 PM
Same pipe diameter... do as the good Cap'n recommends. Why mess up a perfectly good set of SSIs? (IMG:style_emoticons/default/confused24.gif)
orange914 |
Aug 21 2008, 06:36 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
what would that accomplish? the s/s 1.7 and 2.0's have the same i.d. is the 2.0 muffler less restrictive?
mike |
Aug 21 2008, 07:13 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Just curious if anyone here has ever converted a set of Stainless Steel Heat Exchangers over from 1.7 to 2.0 ? (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) All HE's fit on all Motors. They bolt right to the heads. 2.0 liter HE's require 2.0 liter muffler and 2.0 liter muffler hanger. 1.7/1.8 HE's require 1.7/1.8 liter muffler and hanger. That is the simplest setup of parts. You might be able to take an aftermarket muffler and cut off the flanges and weld on the other type of flange to make it work, but the height of the exit of the HE's is different so the resulting height of the muffler will either hit the car, or hang to low. Rich |
JeffBowlsby |
Aug 21 2008, 07:21 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I think he means that 1.7L SSIs are cheaper and more available to come by than the 2.0L units. So why not get the 1.7L units and modify the ends to receive a standard 2.0L muff? Been thinking the same myself but don't know if its possible or what is involved if it is. May be a simple mod, may not work at all depending on the configuration.
Who has both set-ups to compare? |
Aug 21 2008, 07:25 PM
The 2.0 liter muffler or an aftermarket muffler made for 2.0 HE's will not work...its will hit the trunk floor (at least it will make you remove the heat shield)
The 1.7 HE's swing up at the end, the 2.0 liter ones do not. So, you need to buy the correct muffler for the HE or it wont fit. Not to mention the fact that the flanges are different...but I am assuming you weld on new flanges...same issue will occur. I have all of it here...tried, measured...NOPE Rich |
JeffBowlsby |
Aug 21 2008, 07:31 PM
Not sure you get what he is asking for Rich. He is proposing to cut off the ends of 1.7L HEs and mod them to fit a 2.0L muff. Cut off the upturned pipe ends...add level pipes and correct flanges...Can it be done? Convert a 1.7L HE to work with a 2.0L muff. (IMG:style_emoticons/default/idea.gif)
orange914 |
Aug 21 2008, 07:32 PM
I think he means that 1.7L SSIs are cheaper and more available to come by than the 2.0L units. So why not get the 1.7L units and modify the ends to receive a standard 2.0L muff? Been thinking the same myself but don't know if its possible or what is involved if it is. May be a simple mod, may not work at all depending on the configuration. Who has both set-ups to compare? i beleive the 2.0 spread is also different at the flanges (wider). i may be wrong |
t collins |
Aug 21 2008, 07:48 PM
Not sure you get what he is asking for Rich. He is proposing to cut off the ends of 1.7L HEs and mod them to fit a 2.0L muff. Cut off the upturned pipe ends...add level pipes and correct flanges...Can it be done? Convert a 1.7L HE to work with a 2.0L muff. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) You hit the nail on the head |
Tom |
Aug 22 2008, 12:27 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Yep,
Did it for my 76 when I back fitted the exhaust. Bought a set of nice 1.7 SSHE's and had Dave at Triad modify them for me. I needed the 2.0's so I could use his muffler. I understand he now makes a muffler that fits 1.7's. Tom |
Triaddave |
Aug 22 2008, 02:13 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
The modification can be done. I had no problem welding mild steel to stainless.Tom is correct, I now can build an exhaust for any 914 ever built including the 1.7,2.0. and the 75/76 cars and the 6. my best advice is to go with the exhaust that fits the heat exchangers.
MartyYeoman |
Aug 22 2008, 02:31 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Anything can be done if you want it badly enough.
On my car, I took a a set if SSIs (with bad flanges) and cut and modified them to exit as '75-'76 three bolt units. Pictures are here in a previous post. This gives me the benefits of SSIs and lets me bolt up my original CAT muffler if necessary. Dave, I'm glad you have expanded the Triad product line. Any info on the 75/76 units? |
KaptKaos |
Oct 1 2008, 11:52 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Is there any performance advantage to stainless HEs over regular?
Any advantage to 2.0 vs. 1.7/1.8? I thought that all of the pipe interior dimension were the same. Is this true? TIA |
flippa |
Oct 2 2008, 10:05 AM
Advanced Member Group: Members Posts: 3,177 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States |
Jim Kelly posted a thread a while ago that outlined the differences in the system
http://www.914world.com/bbs2/index.php?sho...c=79247&hl= I suppose it could be modified. Anything can be done, it is just a question of how much $$$$$$$. |
mudfoot76 |
Oct 2 2008, 01:36 PM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
Is there any performance advantage to stainless HEs over regular? From what I have seen and experienced (had OE HEs on my old 2L then upgraded to SSIs), I think the biggest advantage is the SSIs weight only about 50% of what the OEMs do. My highly tuned butt-dyno said there was a difference in car performance and I attribute it to overall decrease in vehicle weight. |
t collins |
Oct 2 2008, 05:53 PM
Is there any performance advantage to stainless HEs over regular? Any advantage to 2.0 vs. 1.7/1.8? I thought that all of the pipe interior dimension were the same. Is this true? TIA I think you're correct the inside pipe dimensions are the same. My only reason to ever consider this modification was to be able to use the 1.7/1.8 SSI I have just sitting around collecting dust with the new 2.0L Bursch muffler I already have. |
jimkelly |
Oct 2 2008, 06:33 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
bam - find a set of steel 2.0 he's for now - jim
Lo-Fi Version | Time is now: 21st May 2024 - 07:42 AM |
