the sawtooth build thread |
sawtooth |
Aug 23 2008, 05:56 PM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
Wanted to start a build thread for my na suby conversion. The car is my newly acquired '73 2.0L fi. It is very clean, appearance group, 2nd owner, 88K. I currently use it as my daily driver.
I want to do a suby conversion because I believe the overall package will have the performance, drivability, and dependability I'm looking for. EDIT: I've changed motor selection slightly and am also taking a bigger plunge by going with a suby trans, see Post #49. |
charliew |
Feb 1 2011, 02:45 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Actually you can probably just get the legacy internal parts and put them in your tranny. The 05 legacy tranny I have uses a clutch fork with the pivot ball instead of the wrx style cross shaft throwout arm and it also has a damaged case so I will put the later parts in a earlier tranny.
sawtooth |
Feb 1 2011, 02:52 PM
Actually you can probably just get the legacy internal parts and put them in your tranny. The 05 legacy tranny I have uses a clutch fork with the pivot ball instead of the wrx style cross shaft throwout arm and it also has a damaged case so I will put the later parts in a earlier tranny. Nice, I could keep my cable clutch then. Sounds like a good plan to me, I'll check it out. Thanks! |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:45 AM |
