914/6 number & color question, trunk numbers |
jkp2240 |
Aug 23 2008, 06:38 PM
Newbie Group: Members Posts: 43 Joined: 2-February 04 From: Chicago, IL Member No.: 1,622 |
Hi
I am looking at a 1970 914/6, it has vin sticker and metal tag but numbers in the trunk do not match. Is this correct? Also, code is 14 for signal orange, but it looks like tangerine? Is that possible they mad an error in the tag? |
smontanaro |
Aug 23 2008, 06:48 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
The number in the trunk is the body/chassis number. It will differ from the VIN. On my /6 there is no number on the Karmann plate on the driver side door jamb. I was told recently that this is correct.
Skip |
9146FAN |
Aug 23 2008, 10:11 PM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
If you're referring to the front trunk VIN plate, the VIN will match the A-pillar VIN and the sticker in the drivers door jam.
If you're referring to the number stamped on the floor of the rear trunk, I agree with Skip; the chassis number will not match the VIN. My understanding is that the cars were manufactured in Austria and the Chassis Number was stamped on their assembly line. The cars received their VIN's afterwords at Zuffenhausen by Porsche. This is why the Chassis Numbers never matche the VIN's. Knowing the German's, I doubt that the color number on your car was wrong. Do you have a pic? My six has no number stamped on the Karman plate. Hope this helps. Eddie |
Gustl |
Aug 24 2008, 01:00 AM
914 enthusiast & historian Group: Members Posts: 11,493 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
My understanding is that the cars were manufactured in Austria ... unfortunately not (IMG:style_emoticons/default/biggrin.gif) the bodies came from the same production line than the 914-4 bodies that was is Osnabrück, Germany - at Karmann (IMG:style_emoticons/default/bye1.gif) Gustl |
Gustl |
Aug 24 2008, 01:06 AM
I am looking at a 1970 914/6, it has vin sticker and metal tag but numbers in the trunk do not match. Is this correct? yepp, that's correct the VIN should look like 914.0.43.xxxx the body number in the rear trunk should look like 13xxxx Also, code is 14 for signal orange, but it looks like tangerine? Is that possible they mad an error in the tag? it's more likely that your car got repainted once take a close look at the D.O.T. sticker (driver's side B-column) what colour do you see under the stamped out holes? (IMG:style_emoticons/default/bye1.gif) Gustl |
jkp2240 |
Aug 24 2008, 08:21 AM
The dot sticker looks orange to tangerine color. I have not received the car yet but when I do I can remove the karmin plate and get a better look. Does orange fade to red or tangerine?
Gustl |
Aug 24 2008, 08:57 AM
Does orange fade to red or tangerine? not really (IMG:style_emoticons/default/idea.gif) my car still has some original signal orange paint in the engine bay as well as the front trunk / gas tank area - and it still looks clearly signal orange, but no longer shiny (IMG:style_emoticons/default/bye1.gif) Gustl |
mel reckling |
Aug 28 2008, 07:44 AM
Member Group: Members Posts: 107 Joined: 28-November 07 From: north royalton, ohio Member No.: 8,385 |
My understanding is that the cars were manufactured in Austria ... unfortunately not (IMG:style_emoticons/default/biggrin.gif) the bodies came from the same production line than the 914-4 bodies that was is Osnabrück, Germany - at Karmann (IMG:style_emoticons/default/bye1.gif) Gustl When I first joined here and was entering my car's info into the data base I searched the trunk on my 72 for a number in the area described and couldn't see one. Did it again with a friend, still no number. Does that mean because it never left Osnabruck it never received one? Does anyone here have any info on the 72's assembly and how it differed from the Zuffenhausen ones? I'd kinda like to know what they skimped on to make these 'watered-down' versions. |
1970 Neun vierzehn |
Aug 28 2008, 08:02 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
When I first joined here and was entering my car's info into the data base I searched the trunk on my 72 for a number in the area described and couldn't see one. Did it again with a friend, still no number. Mel, Where exactly did you look? On my '70/4, I had to look real close with a flashlight to see the #s stamped in the rear trunk. They were so faint, that even after owning the car for 30 years and cleaning, detailing and waxing the trunk many times, I never knew the chassis # was there until I read about it on this Forum. The # could be centered, just in front of the trunk lock latch, or off to the right, in front of the t/l assembly. Paul |
davep |
Aug 29 2008, 10:20 AM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
From 1971 it was in front of the right taillight as Paul says. It should be close to 1320107.
Lo-Fi Version | Time is now: 2nd May 2024 - 11:00 PM |
