Nick |
Member ![]() ![]() Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 ![]() |
So back from Africa after two years and am enjoying driving the 3.0 conversion, but one thing is bugging me. The throttle is very stiff at tip in making it very hard to drive smoothly. Its a standard six throttle arrangement with bell crank at the tranny then a rod to a bell crank at the CIS throttle. Cable was new three years ago / 5000 miles. No part of the throttle linkage system seems probematic. disconect cable from throttle pedal and it moves freely. The cable looks fine and all the individual bell cranks move smoothly. Any ideas?
Nick |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Clutch and throttle cable crossed at pedal assembly? Common mistake....take a look
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Uhhhhhhhhhhhhhhhhhhh, the symptoms don't indicate that conclusion. The Cap'n
racerx9146 |
good design never goes out of date.. ![]() ![]() Group: Members Posts: 174 Joined: 1-January 04 From: Sacramento, CA Member No.: 1,483 Region Association: Northern California ![]() |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I put in a new OEM throttle cable a few months ago, and it was very stiff from day 1, but got worse with use. I squirted some tri-flow teflon lubricant spray down the cable and it was a thousand times better, still works great today.
melnyk |
Member ![]() ![]() Group: Members Posts: 104 Joined: 26-July 08 From: wilkes-barre Member No.: 9,359 Region Association: None ![]() |
I put in a new OEM throttle cable a few months ago, and it was very stiff from day 1, but got worse with use. I squirted some tri-flow teflon lubricant spray down the cable and it was a thousand times better, still works great today. my first thought LUBE LUBE LUBE. it moves fine when it has no resistance but once you have a load it rubs against the sheath and if its not lubed too good it will stick. |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
I would lube the cable and check to see that the acc. pedal moves freely........
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,649 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
my throttle is stiff too...could never figure it out
because each part induvidually is great. i have just learned to live with it but that is not a good solution is it (IMG:style_emoticons/default/blink.gif) i am going to lengthen the lower throttle arm at the the tranny by a 10-15 mm |
Cap'n Krusty |
Uhhhhh some suggestion is better than none, its worth checking if he has checked everything else like he indicates Uhhhhhhhhhhhhhhhhhhh, the symptoms don't indicate that conclusion. The Cap'n I dispute the statement that "some suggestion is better than none", especially if the suggestion is less than helpful. Intertwined clutch and throttle cables cause the engine to speed up when the clutch is engaged, as if you'd fully depressed the accelerator pedal. There is really no other possible symptom. If I were to suggest he chase a wild goose, would that be better than remaining silent? The Cap'n |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
Uhhhhh some suggestion is better than none, its worth checking if he has checked everything else like he indicates Uhhhhhhhhhhhhhhhhhhh, the symptoms don't indicate that conclusion. The Cap'n acually it was all checked BUT the throttle body. a big problem i noticed as a fleet mechanic years ago is the difference it makes after cleaning the throttle body. use spacifically marked throttle body cleaner, not carb cleaner as that can be too harsh. i bet you'll see a difference. mike |
Nick |
Thanks for all the suggestions. i'll check the throttle body this PM. Pulling the throttle cable will have to wait for the weekend. If lubing doesn't fix it and I decide to try an new cable a couple of questions. Terry Cable v Factory v patrick thoughts?
Lo-Fi Version | Time is now: 30th August 2025 - 09:08 PM |
